Intel® C++ Compiler
C++14 operator delete[](void*, std::size_t) variant, incorrect size passed
Povlsen__Daniel
Not sure if this is the correct place to report what seems to be a compiler bug, but here goes:
While icc have embraced the C++14 variants of operator delete, it seems to pass an incorrect value for the size parameter.
Reproduction case as an example on Compiler Explorer, where the incorrect assembly is also observablehttps://godbolt.org/g/pPWktV
The second parameter, "the std::size_t size argument must equal the size argument passed to the allocation function that returned ptr." -18.6.1.2 Array forms [new.delete.array], item 12. Right now the compiler seems to pass the size of a single object instead of the size of the entire allocation.
This was initially discovered using the Scudo Hardened Allocator: https://llvm.org/docs/ScudoHardenedAllocator.html
Feel free to ask for additional information.
Cheers,
Daniel
x64-64 icc 18.0.0,  -O3 -std=c++14
#include <cstdint>
struct A {
    A() {
        m_single = new uint16_t;       // Calls operator new(2)
        m_array = new uint16_t[16384]; // Calls operator new[](32768)
    ~A() {
        delete m_single;  // Calls (C++14) operator delete(m_single, 2)
        delete[] m_array; // Incorrectly calls (C++14) operator delete[](m_array, 2)
                          // Should call (C++14) operator delete[](m_array, 32768) or operator delete[](m_array)
    uint16_t *m_single;
    uint16_t *m_array;
A a;
Viet_H_Intel
Hi Daniel,
It looks like 18.0.3 has addressed the problem (see attached screenshot).
Please let us know if the issue still persists.
vahoang@orcsle147:/tmp$ icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.222 Build 20180410
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
Viet_H_Intel
Screenshot of 18.0.0 vs. 18.0.3
