Intel C++ 2016 on Windows is spitting out many warning #809 on code that never gave such warnings with previous versions and for which other compilers do not complain. It is related to virtual destructors in subclasses and says that the exception specification in the subclass destructor is incompatible with that of the overridden destructor. None of them have an explicit exception specification.
For now I'm disabling that warning but this appears to be a compiler issue. Comments?
Stuart
There is a logged issue about 'incompatible exception specification error with inherited virtual destructors - error #809'. The issue has been fixed. The fix will be included in future update of Intel Parallel Studio XE 2016. Thank you for pointing it out.
Noga
Intel Developer Support
OK, thanks for the info.
Stuart
Instead of a warning I am getting an error 809 and I cannot proceed with builds of the rest of my projects. Is there an option to disable this check? When is the update to Intel C++ 16.0 will come out that fixes this issue?
Not all errors #809 are equal. Can you please describe the issue in greater detail and if possible attach a code sample that captures this issue?
Noga
FYI it seems to be fixed in 16.0 Update 1, or at least I can't trigger it easily now.
We had an open issue about a "warning #809", which was fixed in 2016 Update 1. If this is what you have been seeing you should be good.
Compile the attached preprocessed file using the command below gives
..\ace/Service_Object.h(52): warning #809: exception specification for virtual function "ACE_6_3_1::ACE_Service_Object::
~ACE_Service_Object" is incompatible with that of overridden function "ACE_6_3_1::ACE_Shared_Object::~ACE_Shared_Object" virtual ~ACE_Service_Object (void);
which is incorrect to our idea, we don't use exception specifications in our code
icl.exe /Zc:wchar_t /nologo /Wp64 /Qstd=c++11 /Ob0 /W3 /Gm /EHsc /Zi /MDd /GR /Gy /wd4355 /D _DEBUG /D _AMD64_ /D WIN32 /D _WINDOWS /D _WIN64 /D _CRT_SECURE_NO_WARNINGS /D _CRT_SECURE_NO_DEPRECATE /D _CRT_NONSTDC_NO_DEPRECATE /D _WINSOCK_DEPRECATED_NO_WARNINGS /D ACE_HAS_VERSIONED_NAMESPACE=1 /D ACE_BUILD_DLL /D MPC_LIB_MODIFIER=\"d\" /c "destructor.cpp"
