The following example code produces the compiler error "c:/temp/test.cpp(12): error #453: protected function "C1::C1(int)" (declared at line 4) is not accessible through a "C1" pointer or object" using command line "icpc.exe -std=c++11 c:\temp\test.cpp".
class C1 { protected: C1(int a) { } }; class C2 : public C1 { public: C2() : C1{2} { } };
It compiles if we change initializer syntax in line
C2() : C1{2}
to constructor syntax
C2() : C1(2)
Is this a bug? Thank you for clarification in advance.
Hello Martin,
What's your specific Intel compiler version and Visual studio version? Let me try to reproduce the problem first.
Thank you.
QIAOMIN.Q
Intel Developer Support
Please participate in our redesigned community support web site:
User forums: http://software.intel.com/en-us/forums/
Hello QIAOMIN.Q,
well, I'll try to answer:
>...specific Intel compiler version...
As the TOPIC title says we are using version 15.0. Still more specific? Unfortunately "...Composer XE 2015\bin\intel64_mic\Icpc.exe" itself has no embedded file version information. (Accompanying icc.exe in the same folder is version 15.0.0.0).
>...specific ... Visual studio version...
As DESCRIBED we are using icpc.exe from the command line. Without Visual Studio. (Apart from that: We would like to get rid of the MSVC++ compiler. It is unusable from VS2013 Update 2 and completely broken with VS2013 Update 3.)
If I didn't understood you right, please tell me what information you exactly need. Or please tell me if this command line works on your machine.
Best regards, Martin
As there has been only one 15.0 release version, it may not be necessary, but "icpc -V" and "cl" give the full information, including answering the question whether you are looking at ia32 or Intel64.
Command line invocation doesn't change the use of a combination of Microsoft and Intel headers and libraries. Much of the c++11 support depends on VS2013. As you said yourself, VS2013 update version may make a difference, and Microsoft is unlikely to straighten this out without some influential prodding.
(The "intel64_mic>icpc.exe" has version 15.0 Build 2014726.)
Because "intel64\icl.exe" (which has the same reported issue) is more relevant for us at the moment I would like to demonstrate the configuration/procedure for this compiler version:
1) Open a standard cmd-Window (not a Visual Studio command prompt or anything like this).
2) C:\Program Files (x86)\Intel\Composer XE 2015\bin>iclvars.bat intel64 vs2013
3) C:\Program Files (x86)\Intel\Composer XE 2015\bin>intel64\icl.exe -Qstd=c++11 c:\temp\test.cpp
The compiler error is exactly the same as in my first post.
Version numbers:
The "intel64\icl.exe" reports "Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.108 Build 20140726"
The "cl.exe" reports "Microsoft (R) C/C++ Optimizing Compiler Version 18.00.21005.1 for x64".
Thank you in advance.
Hello Martin,
Seems this is also a C++11 related bug. I have reproduced as you said and will enter this issue into our problem-tracking database.Thank you for submitting the issue.I'll get this posted whenever I have an update from our development team.
Thank you.
QIAOMINQ.
This bug still exists in Intel Composer 2016, i.e. icpc version 16.0.0. What's the status on an expected fix?
