Hi, first of all, sorry if i'm posting this in the wrong forum. I'm currently trying to install the Intel C++ Studio XE for Windows on my computer. Unfortunately after unpacking the offline installation file i am getting the following error message "ERROR: The installation is terminated because of unknown error. Suggestions: visit the Support Web Site for a solution to this problem.".
So here i am. Can you help me? thank you in advance for the help.
Hi Johannes,
Could you please look at the checksum of your installation package, and make sure that it is not corrupted? Please find checksum of the version/update you downloaded at here. Let me know if that works.
@Johannes
Have you tried to install Studio XE when Kaspersky AV is disabled?
The new Process Explorer file without Kaspersky AV can be downloaded here https://dl.dropboxusercontent.com/u/14818868/IntelProcMonWithoutKaspersky.PML
However, I am not able to generate a process dump because the Process Explorer throws an access denied error for the Setup.exe.
Do you have a md5 hash?
@Johannes
Thanks for uploading PM dump file.I will look at it tomorrow.
Regarding Process Explorer dump simply do not use it.Better way is to use windbg to collect the full minidump.Hopefully saved trap frame will contain the context of installer thread at the moment of exception.
>>>However, I am not able to generate a process dump because the Process Explorer throws an access denied error for the Setup.exe.>>>
Strange could the Setup.exe be protected process just like DRM processes?
@Johannes
This line looks interesting
>>> C:\Program Files (x86)\Common Files\Intel\Licenses\*.lic RESULT - NO_SUCH_FILE
It seems that IRP_MJ_DIRECTORY_CONTROL cannot file or locate your license file.Prior to exit of Setup.exe process there are failed calls to RegOpenKey such like this one HKCR\CLSID\{FA445657-9379-11D6-B41A-00065B83EE53}.
Btw Kaspersky AV is still running.If you do not perform online installation please disable AV real-time protection.I cannot find any clue in PM dumps.The best option could collecting full process minidump.
Johannes M. wrote:
i tried to do this, but if i am starting the online-installer the process doesn't show up the task manager. anti-virus and firewall are deactivated.
@Sergey
As you may see @Johannes had already tried to perform online installation.
