Intel® C++ Compiler
C++ XE state of C++0x?
kfsone
Is there a page somewhere listing the state of C++ XEs C++0x compatability/support?
- Does it support "auto"?
- Does it support constructor delegation?
- Does it support RValue references / move ctors / operators
Oliver
Andreas_Klaedtke
The compiler documentation for 12.0.0 states in the -std=c++0x section:
c++0x
Enable support for the following C++0x features:
  • Atomic types and operations
  • Scoped enumeration types
  • Defaulted and deleted functions
  • Rvalue references
  • Empty macro arguments
  • Variadic macros
  • Type long long
  • Trailing comma in enum definition
  • Concatenation of mixed-width string literals
  • Extended friend declarations
  • Use of ">>" to close two template argument lists
  • Relaxed rules for use of "typename"
  • Relaxed rules for disambiguation using the "template" keyword
  • "extern template" to suppress instantiation of an entity
  • "auto" type specifier
  • decltype operator
  • static_assert
  • compliant __func__
lambda expressions
There is also the following site on the net:
http://en.chys.info/2009/05/cpp0x-in-icc11/
Giving a few details about the C++0x standard in version 11 of the compiler. I suppose that 12 covers this as well.
I hope that
http://wiki.apache.org/stdcxx/C++0xCompilerSupport
will be updates at some point.
RValue references and auto seem to be supported.
