Hi there,
I was trying to install the C++ non-commercial compiler on my opensuse10.2 and am getting an error related to missing libraries
linux-gate.so.1 =>
libpthread.so.0 => ..
libm.so.6 =>
etc.
Strange because the libraries are there in /lib. Note that I am using suse 10.2 32bits on a thinkpad laptop.
Any help would be greatly appreciated.
Eric
PS: same error when installing the fortran compiler
You should have g++ installed and working before installing the Intel compilers. The Intel installations pick up the library paths from g++ (try g++ -print-search-dirs). g++ is supported up through 4.1.x. icpc may have difficulty with newer versions of g++, but ifort should still work. In a 32-bit linux installation, the installer should attempt to install only the 32-bit Intel compilers.
