Sample code (t0.c):
void* f(void)
1 ? f() : (void)f();
return 0;
Invocation:
icc t0.c -std=c11 -pedantic -Wall -Wextra
Expected diagnostics:
conditional expression where only one operand have void type is forbidden
Actual diagnostics:
<nothing>
Version:
icc 2021.5.0 on x86-64 on Linux
The issue raised by you is reproducible from our end with icc compiler (thanks for bringing this to our notice) whereas the icx compiler is working as expected by throwing a warning. We are working on this issue internally, we will get back to you soon.
Thanks & Regards,
Ditipriya.
We have reported this issue to the concerned development team. They are looking into your issue.
Thanks & Regards,
Ditipriya.
Thank you for your patience.
Not sure if you are aware of it, but the C++ Classic compiler will enter "Legacy Product Support" mode signaling the end of regular updates. Please see the below article for more details.
So we suggest you try with icx compiler (2022.0.0) as it is working as expected by throwing a warning from our end.
Thanks & Regards,
Ditipriya.
@DitiD_Intel Thanks for the link. One question: how exactly Intel's LLVM-based X86 backend is different from LLVM's X86 backend? Where is to read about that?
Intel LLVM compilers are expected to give higher performance than the base clang+LLVM for Intel architecture. The default for the Intel C/C++ compilers going forward are versions (icx) that have adopted the LLVM open source infrastructure.
ICX is Intel nextgen compiler based on Clang /LLVM technology plus Intel proprietary optimizations and code generation.
The latest Intel C/C++ compilers, using LLVM, deliver faster compiler times, better optimizations, enhanced standards support, and support for GPU and FPGA offloading.
Please refer to the link mentioned below for more information.
The version against which you reported your issue is no longer targeted for fixes. Please check out the new versions of Intel oneAPI Toolkits for the latest features.
Thanks and Regards,
Ditipriya.
