Intel® C++ Compiler
C++ compiler won't work
philstewart
I'm trying to compile a c++ program using icpc (version 10.1.015) on Fedora 9. If I compile it with g++ it works fine, but the intel compiler returns the error:
/usr/include/c++/4.3.0/x86_64-redhat-linux/bits/c++locale.h(94): error: argument of type "__va_list_tag *" is incompatible with parameter of type "char *"
const int __ret = __builtin_vsnprintf(__out, __size, __fmt, __args);
I have no idea what to do, I'd rather not use g++ as I find it too slow for what I need.
Any thoughts/suggestions would be greatly appreciated.
Phil
TimP
Black Belt
icpc isn't yet compatible with the latest libstdc++, and hasn't had a chance to catch up with FC9. g++ 4.1 is fully supported, and 4.2 normally works with icpc, with minor adjustments (although I can't vouch for FC9 otherwise). Install an older gcc and put it first on PATH and LD_LIBRARY_PATH. Also, check your glibc and kernel versions against the documented supported range, although those are less likely to be a problem, and also not so easy to backdate, other than by installing a supported distro.
philstewart
Thanks for the quick reply, solves my problem! Cheers, Phil
