I am trying to compile a C++ code which has the following include files:
#include <iostream>
#include <fstream>
#include <iomanip>
#include <cmath>
#include <string>
#include <vector>
When I was trying to compile, it was apparently looking for these include files and following was the error I got:
icc: error #10417: Problem setting up the Intel(R) Compiler compilation environment. Requires 'C++ include files' setting gathered from 'g++'
Following are the details of the compiler I was using:
OS info and version: Red Hat Enterprise Linux 7 64-bit
Compiler version: parallel_studio_xe_2020_update4_professional_edition
Where can I get these include files from, are these compiler specific?
Thank you.
Thank you for posting in Intel C++ Compiler forum. Could you please share the outputs of the following?
1. echo $PATH
2. echo $LD_LIBRARY_PATH
3. gcc --version
4. icc --version
5. Please ensure libraries are present in the standard path, /usr/include/c++/<version>/, and please share with us the screenshot of the contents of the folder
Gopika
Hi Gopika,
Thank you for your response and thank you very much for your help with my question.
Following are the outputs that you asked:
1. echo $PATH:
/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/kveera/.local/bin:/home/kveera/bin
2. echo $LD_LIBRARY_PATH:
(blank)
3. gcc --version:
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-44)
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
4. icc --version:
bash: icc: command not found...
the "compilers_and_libraries_2020" folder which came during the original installation was not changed. The current path is as shown in the following (/home/kveera/Intel), this was the folder into which was selected during the original installation
/usr/include/c++/<version>/, and please share with us the screenshot of the contents of the folder:
Following are the contents of the folder:
[root@localhost Intel]# pwd
/home/kveera/Intel
[root@localhost Intel]# ls -ltr
total 32
drwxr-xr-x. 26 root root 4096 Sep 27 16:08 vtune_profiler_2020.3.0.612611
drwxr-xr-x. 4 root root 34 Oct 1 06:51 compilers_and_libraries_2020.4.304
drwxr-xr-x. 4 root root 24 Oct 14 04:39 documentation_2020
lrwxrwxrwx. 1 root root 49 Feb 8 09:12 vtune_profiler -> /home/kveera/Intel/vtune_profiler_2020.3.0.612611
lrwxrwxrwx. 1 root root 49 Feb 8 09:12 vtune_profiler_2020 -> /home/kveera/Intel/vtune_profiler_2020.3.0.612611
lrwxrwxrwx. 1 root root 91 Feb 8 09:12 performance_snapshot -> /home/kveera/Intel/vtune_profiler_2020.3.0.612611/documentation/en/performance_snapshot.htm
drwxr-xr-x. 2 root root 4096 Feb 8 09:12 performance_snapshots_2020.3.0.0.612611
lrwxrwxrwx. 1 root root 58 Feb 8 09:12 performance_snapshots -> /home/kveera/Intel/performance_snapshots_2020.3.0.0.612611
drwxr-xr-x. 3 root root 15 Feb 8 09:13 samples_2020
drwxr-xr-x. 20 root root 4096 Feb 8 09:14 inspector_2020.3.0.604771
lrwxrwxrwx. 1 root root 44 Feb 8 09:14 inspector -> /home/kveera/Intel/inspector_2020.3.0.604771
lrwxrwxrwx. 1 root root 44 Feb 8 09:14 inspector_2020 -> /home/kveera/Intel/inspector_2020.3.0.604771
lrwxrwxrwx. 1 root root 42 Feb 8 09:14 advisor -> /home/kveera/Intel/advisor_2020.3.0.607294
lrwxrwxrwx. 1 root root 42 Feb 8 09:14 advisor_2020 -> /home/kveera/Intel/advisor_2020.3.0.607294
drwxr-xr-x. 22 root root 4096 Feb 8 09:14 advisor_2020.3.0.607294
drwxr-xr-x. 3 root root 20 Feb 8 09:15 ide_support_2020
drwxr-xr-x. 2 root root 23 Feb 8 09:15 impi
drwxr-xr-x. 9 root root 92 Feb 8 09:21 debugger_2020
lrwxrwxrwx. 1 root root 29 Feb 8 09:21 parallel_studio_xe_2020 -> parallel_studio_xe_2020.4.912
drwxr-xr-x. 7 root root 4096 Feb 8 09:23 conda_channel
drwxr-xr-x. 16 root root 4096 Feb 8 09:24 intelpython3
drwxr-xr-x. 3 root root 18 Feb 8 09:24 compilers_and_libraries_2020
lrwxrwxrwx. 1 root root 28 Feb 8 09:24 compilers_and_libraries -> compilers_and_libraries_2020
lrwxrwxrwx. 1 root root 33 Feb 8 09:24 lib -> compilers_and_libraries/linux/lib
lrwxrwxrwx. 1 root root 37 Feb 8 09:24 include -> compilers_and_libraries/linux/include
lrwxrwxrwx. 1 root root 33 Feb 8 09:24 man -> compilers_and_libraries/linux/man
lrwxrwxrwx. 1 root root 33 Feb 8 09:24 ipp -> compilers_and_libraries/linux/ipp
lrwxrwxrwx. 1 root root 35 Feb 8 09:24 mpirt -> compilers_and_libraries/linux/mpirt
lrwxrwxrwx. 1 root root 33 Feb 8 09:24 mkl -> compilers_and_libraries/linux/mkl
lrwxrwxrwx. 1 root root 34 Feb 8 09:24 daal -> compilers_and_libraries/linux/daal
lrwxrwxrwx. 1 root root 33 Feb 8 09:24 tbb -> compilers_and_libraries/linux/tbb
lrwxrwxrwx. 1 root root 34 Feb 8 09:24 pstl -> compilers_and_libraries/linux/pstl
drwxr-xr-x. 2 root root 4096 Feb 8 09:24 bin
drwxr-xr-x. 5 root root 4096 Feb 8 09:24 parallel_studio_xe_2020.4.912
Thank you for the information. It seems you haven’t sourced the compilervars.sh file. Please source the compilervars.sh file, it is present in the parallel studio folder path
<path to parallel studio folder>/intel-parallel-studio/compilers_and_libraries_<version>/linux/bin
To source the file, execute
source compilervars.sh
See if the error persists
Gopika
Hi Gopika,
When I tried to source by using the following command:
source /home/user/Intel-sw-download-folder/bin/compilervars.sh
following was the result:
compilervars.sh [-arch] <arch> [-platform <platform>]
<arch> must be one of the following:
ia32 : Set up for IA-32 target.
intel64 : Set up for Intel(R)64 target.
<platform> must be of the following:
android : Set to Android* target.
linux : Set to Linux* target.(default)
If the arguments to the sourced script are ignored (consult docs
for your shell) the alternative way to specify target is environment
variables COMPILERVARS_ARCHITECTURE to pass <arch> to the script
and COMPILERVARS_PLATFORM to pass <platform>
So, I tried the following command:
source /home/user/Intel-sw-download-folder/bin/compilervars.sh intel64 linux
yet again, it gave me the same result as the following:
I appreciate your help in this regard.
Thank you very much.
Thank you for the update. Please try these solutions. See whether you can include files after that.
1.
source compilervars.sh intel64
instead of source compilervars.sh intel64 linux and try icc --version. Ensure you're getting an output.
2. Ensure you’ve installed all the components in parallel studio xe, including intel C++ Compiler and sourced psxevars.sh.
NOTE : Intel Parallel Studio has been rebranded as oneAPI. To get the equivalent software development environment as Intel Parallel Studio download the oneAPI Base Toolkit and the oneAPI HPC Toolkit from here, https://software.intel.com/content/www/us/en/develop/tools/oneapi/all-toolkits.html.
Gopika
We haven’t heard from you in a while. Did the solution work for you? Are you able to include the files now? Let us know your updates.
Gopika
Hi Gopika,
Thank you for checking back with me. As you had suggested I tried the following two commands and the following are the outputs that I got:
1. source compilervars.sh intel64 instead of source compilervars.sh intel64 linux:
command used: source /home/user/Intel-sw-download-
This appeared to have worked because upon executing the command I didn't get any message..
and try icc --version. Ensure you're getting an output.:
command used: /home/user/Intel-sw-download-
Following was the message that I got:
2. Ensure you’ve installed all the components in parallel studio xe, including intel C++ Compiler:
I believe following are the components under my "parallel_studio_xe_2020.4.912" directory:
advisor_2020 , bin compilers_and_libraries_2020, documentation_2020, ide_support_2020, inspector_2020, licensing, man, psxevars.csh, psxevars.sh, samples_2020, uninstall, uninstall_GUI.sh, uninstall.sh, vtune_profiler_2020.
and sourced psxevars.sh:
Intel(R) Parallel Studio XE 2020 Update 4 for Linux*
Copyright 2009-2020 Intel Corporation.
Then, I tried the previous command again (/home/user/Intel-sw-download-
Yet again I got the following message:
icc: error #10417: Problem setting up the Intel(R) Compiler compilation environment. Requires 'C++ include files' setting gathered from 'g++'.
Thank you.
Thank you for the update. Compiling does not require complete path. We suggest the following steps again and see if you can compile your program. Please share the output after each step
1. Go to the folder where the C++ program to be executed is present.
2. Execute
source <path to parallel studio folder>/intel-parallel-studio/compilers_and_libraries_<version>/linux/bin/compilervars.sh intel64
3. Execute (full path not required, /home/user/Intel-sw-download-folder/bin/icc *.cc — not required)
icc --version
4. Execute either of the below. Full path is not required.( /home/user/Intel-sw-download-folder/bin/icc *.cc — not required)
icc filename.c //for c program
icpc filename.cpp //for c++ program
where filename is the program to be executed.
Hope this helps
Gopika
Hi Gopika,
I still cannot compile my program with the steps mentioned here. I am sharing the output for each step:
1. Go to the folder where the C++ program to be executed is present.: Done
2. Execute:
source /home/User/Intel/compilers_and_libraries_2020/linux/bin/compilervars.sh intel64
Output: None (which is understood as the file is correctly sourced)
icc --version
Output:
icc (ICC) 19.1.3.304 20200925
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
Executed: icpc filename.cpp
Output: icpc: error #10417: Problem setting up the Intel(R) Compiler compilation environment. Requires 'install path' setting gathered from 'g++'
Thank you for your help in my trials to compile my program.
We haven’t heard from you in a while. Did the solution work for you? Are you able to include the files now? Can we discontinue monitoring this thread? Let us know your updates.
Gopika
Thank you for the update. Please try the below steps.
1. Specify the gcc version while compiling like below.
$ export GXX_INCLUDE=/usr/lib/gcc/x86_64-pc-linux-gnu/6.4.1/include/c++
$ icc -gcc-name=gcc-6 filename.c
$ icpc -gxx-name=g++-6 filename.cpp
See whether the error occurs.
2. Try a simple hello world program like below and see if the error occurs.
#include<iostream>
using namespace std;
int main()
cout<<"hello world";
return 0;
Compile and execute it
icpc filename.cpp
./a.out
Hope this helps you
Gopika
Hi Gopika,
Thank you for your help.
Following are the problems that I still have when I do as suggested:
In the following path of my compiler where I have the "lib" folder:
/home/user/Intel-compiler-folder/lib/intel64
The "lib" folder had only the following:
intel64 -> intel64_lin/
intel64_lin
ia32_lin
I did not find "gcc". There were several lib*.* files.
I did not find "gcc" neither in the "/home/user/Intel-compiler-folder/bin" folder. I had only the "icc" and the "icpc"
2. I tried a small hello world program (hw.cpp) as suggested and tried to compile with the following commands and following were the results/responses:
Also tried: /home/user/Intel-compiler-folder/bin/iccvars.sh intel64
Response: None
/home/user/Intel-compiler-folder/bin/icpc hw.cpp
Response:
Thank you once again for your help in my trials to compile my code.
Thank you for the update. Please follow the below steps:
1. To execute
export GXX_INCLUDE=/usr/lib/gcc/x86_64-pc-linux-gnu/<g++ version>/include/c++
First execute
which g++
for us it displayed /usr/bin/g++, it would be different for you.
Trace this path to reach the include folder. Replace this path in the export statement mentioned above. Then compile the program by specifying the g++ version.
$ icpc -gxx-name=g++-<g++ version> filename.cpp
2. While compiling the hello world program, whole path is not required,
Instead of /home/user/Intel-compiler-folder/bin/icpc hw.cpp
Compile using
icpc hw.cpp
So, the order would be
>Go to the folder where hw.cpp is present.
>source <path to compilervars.sh>/compilervars.sh intel64
>icpc -gxx-name=g++-<g++ version> hw.cpp
Please share with us the outputs that you obtain after each step.
Gopika
Hi Gopika,
Thank you once again for your detailed reply regarding helping me to compile my code.
When I try to execute: "which g++" it gives me the following output, can you please suggest me if you might know the remedy for this:
/usr/bin/which: no g++ in (/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/kveera/.local/bin:/home/kveera/bin).
Thank you.
Hi
We haven’t heard from you in a while. Is your issue resolved? Can we discontinue monitoring this thread?
Gopika
Referring the above posts, it seems the gcc is not correctly installed. Please follow the below steps so that we can ensure gcc is correctly installed and intel c++ compiler version is compatible to the gcc version.
1. Uninstall the intel toolkits (parallel studio xe)
2. Reinstall the current gcc version correctly or upgrade to the latest version of gcc.
3. Ensure it is correctly installed by executing
gcc --version
and
which gcc
4. For more information on gcc - icc compatibility please refer
https://software.intel.com/content/www/us/en/develop/articles/intel-cpp-compiler-release-notes.html
5. Re-install the intel toolkits (parallel studio xe)
Gopika
Hi
We haven’t heard from you in a while. Are you able to compile after reinstalling gcc and the intel toolkits? Can we discontinue monitoring this thread?
Gopika
Hi Gopika,
Thank you again for your help in my trials to compile my code.
I was able to re-install the gcc and the intel toolkits (after using the command "yum groupinstall development" in my RedHat Linux).
gcc --version:
which gcc:
/usr/bin/gcc
However, I am still unable to compile my code. Following are the steps that I followed (along with the results in compiling the "hello-world program":hw.cpp
When in the folder where the C++ program to be executed is present:
1. source /home/kveera/Intel/bin/compilervars.sh intel64
After tracing the path to the include folder:
2. export GXX_INCLUDE=/usr/lib/gcc/x86_64-redhat-linux/4.8.5/include
3. Tried to compile using the following command:
icpc hw.cpp
Following was the result/output:
hw.cpp(1): catastrophic error: cannot open source file "iostream"
#include <iostream>
compilation aborted for hw.cpp (code 4)
Finally, I checked at the following location:
there was indeed no "iostream.h" file.
Any help in this regard is greatly appreciated.
Thank you for the update. The error seems to be occurring because of the export command. Please compile the program without the export GXX_INCLUDE statement. So, the steps to be executed would be
icpc hw.cpp
Hope this helps
Gopika
Hi
Gopika
