I am trying to compile a C++ code which has the following include files:
#include <iostream>
#include <fstream>
#include <iomanip>
#include <cmath>
#include <string>
#include <vector>
When I was trying to compile, it was apparently looking for these include files and following was the error I got:
icc: error #10417: Problem setting up the Intel(R) Compiler compilation environment. Requires 'C++ include files' setting gathered from 'g++'
Following are the details of the compiler I was using:
OS info and version: Red Hat Enterprise Linux 7 64-bit
Compiler version: parallel_studio_xe_2020_update4_professional_edition
Where can I get these include files from, are these compiler specific?
Thank you.
- « Previous
- 1
- 2
- Next »
Hi Gopika,
I believe my issues with compiling my "hello world" program are now resolved. Thank you very much for your help all along.
Following were the steps that went through in successfully compiling:
1. As the first step I installed my virtual machine (Linux) afresh.
2. Re-installed "parallel_studio_xe_2020_update4_professional_edition"
3. When in the directory of my "hello world" (hw.cpp) executed the following:
source /opt/intel/bin/compilervars.sh intel64
4. Then executed: icpc hw.cpp
5. This produced the output "a.out"
6. Then executed: ./a.out to view "hello world" on the terminal.
I have one final question or request for your suggestion, if I may ask in this thread. Do you have suggestions for an IDE (for Linux) that I could install for C++? Your answer or suggestion in this regard would be greatly appreciated.
Thanks again.
Hi Gopika,
One other critical step that I wanted to mention in this thread is that in my RedHat Linux I had to execute the following command:
yum groupinstall development
which helped me install gcc-c++
Also finally, all the necessary C++ include files were located at: /usr/include/c++/4.8.2 (which I didn't have to source to compile my program successfully).
As you had suggested, all I had to execute were the following two steps:
icpc hw.cpp
Thanks again.
Thank you for the confirmation. Glad to know your issue is resolved. And for the IDEs for Linux and supporting C++, recommended ones with intel toolkits are eclipse and vscode. If you need any additional information, please submit a new question as this thread will no longer be monitored as your initial issue is resolved.
Gopika
- « Previous
- 1
- 2
- Next »
