Intel C++ Compiler (icpc (ICC) 19.1.0.166 20191121) seems to mishandle “injected-class-name” as described in (C++ 2014 Standard draft: 14.6.1). The compiler seems to pass type-name instead of template-name as a template template argument when instantiating method/function template from within template class itself (see code below). This seems to violate second bullet-point (see https://en.cppreference.com/w/cpp/language/injected-class-name#In_class_template), which states that the injected-class-name is treated as a template-name of the class template itself when: "it is used as a template argument that corresponds to a template template parameter".
Therefore following code fails to compile ("Foo" in "Bar<Foo>()" call seems to be handled as "Bar<Foo<int> >()" instead as template-name itself):
template<typename T> class Foo { public: template<template<typename> class VT> void Bar() {} void Bar2() { Bar<Foo>(); } }; int main(int argc, char *argv[]) { Foo<int> foo; foo.Bar2(); return 0; }
This can be fixed as
template<typename T> class Foo { public: template<template<typename> class VT> void Bar() {} void Bar2() { Bar<::Foo>(); } }; int main(int argc, char *argv[]) { Foo<int> foo; foo.Bar2(); return 0; }
or by aliasing "Foo" template as in
template<typename TA> using FooAlias = Foo<TA>; ... Bar<FooAlias>(); ...
- Tags:
- Bug
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi Filip,
Thanks for reporting this bug. It is reproducible at my end. I will escalate this issue to the concerned team,
--Rahul
This will be fixed in the upcoming release.
This has been fixed in OneAPI tool kit. We will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
