Intel® C++ Compiler
C++ -vec-report problem
Jamil_A_
 Hi
  Activating -vec-report during compilation of a c++ shared library fails to compile but works for the c compiler.
   Has anyone seen the same problem?
#include <iostream>
int main()
std::cout << "Hello World\n";
return 1;
> icpc -vec-report3 -O2  -fPIC -c test.cxx -o test.o
> icpc test.o -shared -o test.so
ld: test.o: relocation R_X86_64_PC32 against undefined symbol `DW.ref.__gxx_personality_v0' can not be used when making a shared object; recompile with -fPIC
ld: final link failed: Bad value
> icpc --version
icpc (ICC) 12.1.0 20110811
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
Georg_Z_Intel
Hi, this problem has been fixed with Intel(R) Composer XE 2011 Update 11 and higher (aka. 12.1.5). Best regards, Georg Zitzlsberger
