Intel® C++ Compiler
CPP calls FORTRAN
maksyutov__malik
Hello!
I have a problem with the mixed languages programming.
This is a task with the cpp/fortran pointers passing when the 2d dynamic array was created.
Main CPP program is calling FORTRAN array filling subroutine. Can't get the right results, please help.
PS I can't using an one-dimensional array, like this arr[i*N +j] :(
CPP TEXT:
#include <cstdlib>
#include <iostream>
using namespace std;
extern "C" void fill_array(int **, int, int);
int main()
    int i, j, N, M;
    int **arr;
    cout<<endl<<"rows Number  ="<<endl;    cin>>M;
    cout<<endl<<"cols Number  ="<<endl;    cin>>N;
    cout<<endl;
    arr = new int*;
    for(int i = 0; i < N; i++)arr = new int;
    fill_array(arr,M,N);
    for( i = 0; i < N; i++)
      for( j = 0; j < M; j++)
         cout << arr<<" ";
      cout<<endl;
    for( i = 0; i < N; i++)delete [] arr;
    delete [] arr;
    return EXIT_SUCCESS;
FORTRAN TEXT:
SUBROUTINE FILL_ARRAY(C,M,N)BIND(C,name="fill_array")
    USE, INTRINSIC                         :: ISO_C_BINDING
    INTEGER(KIND=C_INT), INTENT(IN), VALUE :: N,M
    TYPE(C_PTR)                            :: C
    INTEGER(C_INT), POINTER      :: F(:,:)
    INTEGER                                  :: I,J, RANK
    RANK = N*M
    CALL C_F_POINTER(C,F,[RANK])
    DO I=1, M
        DO J = 1, N
            F(I, J) = I + J
        ENDDO
    ENDDO
END SUBROUTINE
Typical output for matrix 3x3 is not correct:
2 3 4
0 3 4
0 0 4
jimdempseyatthecove
Fortran allocated arrays are contiguous. Your C++ code first allocates an array of int pointers, then allocates to each pointer a row of data. These rows are not contiguous.
What you should do is after allocating the C++ array of int pointers, allocate a buffer of int, size M*N integers, then construct the pointers into this contiguous buffer, and insert them into your int** array. The base of this array is passed to Fortran (plus M and N). From these you can construct a proper pointer to use as F.
To construct a proper value for F use
 CALL C_F_POINTER(C,F,[M,N]) ! or N,M
or
INTEGER :: RANK(2) ! 1D integer array
RANK = [M,N] ! or [N,M] ! populate with [columns, rows]
 CALL C_F_POINTER(C,F,RANK)
And when (if) you later delete the data, you do not delete the individual rows, instead delete the blob of data, followed by the array of int*'s.
Jim Dempsey
maksyutov__malik
Thank you Jim for your detailed explanation!
I have made all of you recommendation you noted,
for cpp code
#include <cstdlib>
#include <iostream>
int main()
    int i,j,N, M;
    int **arr, *buf;
    cout<<endl;
    arr = new int*;
    buf = new int[M*N];
    for( i = 0; i < M; i++)arr = &buf[N*i];
         cout << arr<<" ";
      cout<<endl;
    delete[] buf;
    delete [] *arr;
and FORTRAN
    TYPE(C_PTR)                            :: C
    INTEGER                                :: RANK(2)
    RANK = [M,N]
    DO I=1, M
        DO J = 1, N
            F(I, J) = I + J
        ENDDO
    ENDDO
END SUBROUTINE
Correct results , but the problem still exists...in the new messages, maybe incorrect at the pointers deleting?
rows Number  =
3
cols Number  =
3
2 3 4
3 4 5
4 5 6
*** Error in `/home/mmax/DevStudioProjects/LABcpp/dist/Debug/Intel-Linux/labcpp': double free or corruption (fasttop): 0x000000000116e030 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x816b9)[0x7f8f1d7136b9]
/home/mmax/DevStudioProjects/LABcpp/dist/Debug/Intel-Linux/labcpp[0x400e68]
/lib64/libc.so.6(__libc_start_main+0xf5)[0x7f8f1d6b4545]
/home/mmax/DevStudioProjects/LABcpp/dist/Debug/Intel-Linux/labcpp[0x400ac9]
======= Memory map: ========
00400000-00403000 r-xp 00000000 fd:02 1073927361                         /home/mmax/DevStudioProjects/LABcpp/dist/Debug/Intel-Linux/labcpp
00602000-00603000 r--p 00002000 fd:02 1073927361                         /home/mmax/DevStudioProjects/LABcpp/dist/Debug/Intel-Linux/labcpp
00603000-00604000 rw-p 00003000 fd:02 1073927361                         /home/mmax/DevStudioProjects/LABcpp/dist/Debug/Intel-Linux/labcpp
0116e000-0118f000 rw-p 00000000 00:00 0                                  [heap]
7f8f18000000-7f8f18021000 rw-p 00000000 00:00 0
7f8f18021000-7f8f1c000000 ---p 00000000 00:00 0
7f8f1d48e000-7f8f1d490000 r-xp 00000000 fd:00 67311862                   /usr/lib64/libdl-2.17.so
7f8f1d490000-7f8f1d690000 ---p 00002000 fd:00 67311862                   /usr/lib64/libdl-2.17.so
7f8f1d690000-7f8f1d691000 r--p 00002000 fd:00 67311862                   /usr/lib64/libdl-2.17.so
7f8f1d691000-7f8f1d692000 rw-p 00003000 fd:00 67311862                   /usr/lib64/libdl-2.17.so
7f8f1d692000-7f8f1d855000 r-xp 00000000 fd:00 67311856                   /usr/lib64/libc-2.17.so
7f8f1d855000-7f8f1da55000 ---p 001c3000 fd:00 67311856                   /usr/lib64/libc-2.17.so
7f8f1da55000-7f8f1da59000 r--p 001c3000 fd:00 67311856                   /usr/lib64/libc-2.17.so
7f8f1da59000-7f8f1da5b000 rw-p 001c7000 fd:00 67311856                   /usr/lib64/libc-2.17.so
7f8f1da5b000-7f8f1da60000 rw-p 00000000 00:00 0
7f8f1da60000-7f8f1da75000 r-xp 00000000 fd:00 67991406                   /usr/lib64/libgcc_s-4.8.5-20150702.so.1
7f8f1da75000-7f8f1dc74000 ---p 00015000 fd:00 67991406                   /usr/lib64/libgcc_s-4.8.5-20150702.so.1
7f8f1dc74000-7f8f1dc75000 r--p 00014000 fd:00 67991406                   /usr/lib64/libgcc_s-4.8.5-20150702.so.1
7f8f1dc75000-7f8f1dc76000 rw-p 00015000 fd:00 67991406                   /usr/lib64/libgcc_s-4.8.5-20150702.so.1
7f8f1dc76000-7f8f1dd5f000 r-xp 00000000 fd:00 67312174                   /usr/lib64/libstdc++.so.6.0.19
7f8f1dd5f000-7f8f1df5f000 ---p 000e9000 fd:00 67312174                   /usr/lib64/libstdc++.so.6.0.19
7f8f1df5f000-7f8f1df67000 r--p 000e9000 fd:00 67312174                   /usr/lib64/libstdc++.so.6.0.19
7f8f1df67000-7f8f1df69000 rw-p 000f1000 fd:00 67312174                   /usr/lib64/libstdc++.so.6.0.19
7f8f1df69000-7f8f1df7e000 rw-p 00000000 00:00 0
7f8f1df7e000-7f8f1e07f000 r-xp 00000000 fd:00 67311864                   /usr/lib64/libm-2.17.so
7f8f1e07f000-7f8f1e27e000 ---p 00101000 fd:00 67311864                   /usr/lib64/libm-2.17.so
7f8f1e27e000-7f8f1e27f000 r--p 00100000 fd:00 67311864                   /usr/lib64/libm-2.17.so
7f8f1e27f000-7f8f1e280000 rw-p 00101000 fd:00 67311864                   /usr/lib64/libm-2.17.so
7f8f1e280000-7f8f1e2a2000 r-xp 00000000 fd:00 67311849                   /usr/lib64/ld-2.17.so
7f8f1e482000-7f8f1e488000 rw-p 00000000 00:00 0
7f8f1e49d000-7f8f1e4a1000 rw-p 00000000 00:00 0
7f8f1e4a1000-7f8f1e4a2000 r--p 00021000 fd:00 67311849                   /usr/lib64/ld-2.17.so
7f8f1e4a2000-7f8f1e4a3000 rw-p 00022000 fd:00 67311849                   /usr/lib64/ld-2.17.so
7f8f1e4a3000-7f8f1e4a4000 rw-p 00000000 00:00 0
7ffeaa19c000-7ffeaa1bd000 rw-p 00000000 00:00 0                          [stack]
7ffeaa1c9000-7ffeaa1cb000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
RUN FINISHED; Aborted; core dumped; real time: 2s; user: 0ms; system: 0ms
jimdempseyatthecove
wrong>> delete [] *arr;
delete [] arr;
Jim Dempsey
jimdempseyatthecove
Also, the row and column index positions differ between Fortran and C++
C++ Array[row][col]
Fortran Array(col, row)
Jim Dempsey
maksyutov__malik
Oh, stupped error! :)
Thank you again, the wrong string was excluded by me:   "delete [] *arr;"
PS. Yes Jim, i know about  "backward" indexing in the arrays passing way.
Malik.
jimdempseyatthecove
IMHO C/C++ is backwards... due to it not supporting directly multi-dimensional arrays (it syntactically appears to do so through use of arrays of pointers).
Jim Dempsey
