Intel® C++ Compiler
7840 Discussions
Call to custom cotd function taking argument by reference seemingly elided
Ryan_L_1
I've got some code which contains a function with signature
/* cotd.h */
#ifndef COTD_PTR_H
#define COTD_PTR_H
void cotd(double *x);
#endif
that updates the value in x, say by adding 2 for demonstration. When I invoke cotd with the address of a double, the value is never changed, and the assembly from passing /S contains no call to cotd when cotd is in a separate compilation unit from the call and no debug flags (e.g. /Z7) are passed.
Details follow.
Implementation:
/* cotd.c */
#include "cotd.h"
void cotd(double *x) {
    *x = 2.0+*x;
Useage:
/* cotdissue.c */
#include "stdio.h"
#include "cotd.h"
int main(void) {
    double x = 1.23;
    printf("Initial x = %g\n", x);
    cotd(&x);
    printf("x = %g; expected = 3.23\n",x);
    return 0;
Compiling without /Z7 and executing produces:
icl  /c /nologo /MD /I "Z:\sandbox\rlivings\temp\sparse\iclrepro"  "cotdissue.c"
icl  /c /nologo /MD /I "Z:\sandbox\rlivings\temp\sparse\iclrepro"  "cotd.c"
link  /nologo /NODEFAULTLIB:LIBCMT  /OUT:cotdissue.exe   cotdissue.obj cotd.obj
Build completed using compiler intelc13msvs2013
cotdissue.exe
Initial x = 1.23
x = 1.23; expected = 3.23
showing that x was never updated on the call to cotd. The assembly generated from cotdissue.c is:
main	PROC
.B1.1::                         ; Preds .B1.0
        sub       rsp, 40                                       ;4.16
        mov       rdx, 0000000000H                              ;4.16
        mov       ecx, 3                                        ;4.16
        call      __intel_new_feature_proc_init                 ;4.16
                                ; LOE rbx rbp rsi rdi r12 r13 r14 r15 xmm6 xmm7 xmm8 xmm9 xmm10 xmm11 xmm12 xmm13 xmm14 xmm15
.B1.6::                         ; Preds .B1.1
        stmxcsr   DWORD PTR [32+rsp]                            ;4.16
        lea       rcx, QWORD PTR [_2__STRING.0.0.1]             ;6.5
        or        DWORD PTR [32+rsp], 32832                     ;4.16
        ldmxcsr   DWORD PTR [32+rsp]                            ;4.16
        movsd     xmm1, QWORD PTR [_2il0floatpacket.0]          ;6.5
        movd      rdx, xmm1                                     ;6.5
        call      QWORD PTR [__imp_printf]                      ;6.5
.B1.2::                         ; Preds .B1.6
        movsd     xmm1, QWORD PTR [_2il0floatpacket.0]          ;8.5
        lea       rcx, QWORD PTR [_2__STRING.1.0.1]             ;8.5
        movd      rdx, xmm1                                     ;8.5
        call      QWORD PTR [__imp_printf]                      ;8.5
.B1.3::                         ; Preds .B1.2
        xor       eax, eax                                      ;9.12
        add       rsp, 40                                       ;9.12
        ret                                                     ;9.12
        ALIGN     16
                                ; LOE
.B1.4::
; mark_end;
main ENDP
Some observations:
  1. Passing /Z7 produces the desired result, 3.23 for x
  2. There are no warnings that cotd may conflict with a built-in function. Are we possibly getting side effect information from the known trig function?
  3. Changing the name of cotd to bcotd produces expected results without /Z7
Any thoughts would be appreciated. I know that I can rename my function as a workaround but the incorrect answer without any notification is concerning to me.
Anoop_M_Intel
Hi Ryan,
I can reproduce this problem on my end. I can check with the compiler development engineers on this. In the meantime, you can try the following:
>icl cotdissue.c cotd.c /Qno-builtin-cotd
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.2.180 Build 20160204
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
cotdissue.c
cotd.c
Microsoft (R) Incremental Linker Version 12.00.31101.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:cotdissue.exe
cotdissue.obj
cotd.obj
>cotdissue.exe
Initial x = 1.23
x = 3.23; expected = 3.23
The compiler option /Qno-builtin-<function name> will not link to the builtin function rather link with the user defined one as you can above. Documentation on this option is available at https://software.intel.com/en-us/node/581706.
Thanks and Regards
Anoop
Ryan_L_1
Thanks for the quick reply Anoop. I confirm that your workaround succeeds and am interested to hear what the consensus on the behavior is.
