Hi, I want to use C++ compilers on my AMD processor. I use Windows as OS, and I have installed Visual Basic and have Intel oneAPI Base Toolkit and Intel oneAPI HPC Toolkit. But when I try to run a makefile, doesn't recognize the intel compilers? What do I need to do to use these compilers?
Hi Beatriz,
Thank you for posting in Intel C++ Compiler forum. About Intel Compiler not being recognized during running of makefile, please try the steps mentioned under “Using Makefiles to Store Information for Compilation on Windows*” in
To modify makefile to use the Intel C++ compiler, please refer the steps under “Modified makefile for the Intel® C++ Compiler”
If the issue persists, please provide us with the following details:
1. Error screenshot/log
2. Makefile that you are trying to run
3. Steps/ Commands used to reproduce the issue
Gopika
Yes, Intel C++ compiler generates code to be run on x86 and x86_64 architectures.
We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
