Can I find a tutorial or a news about using eclipse IDE with Intel Compiler, Linux or Windows ?
Thanks...
As far as 7.1 is concerned, I think you'll have to rely on what you find at the Eclipse site. Plugging your question into Google produces interesting references. I imagine there may be some interest here if you have any success with this.
I tried using Intel compiler with Eclipse IDE, it worked fine.
You just need to download CDT plugins.
try these steps -
- set Intel compiler path
- start eclipse IDE with CDT
- create a new project -> add source files and a Makefile
- use icc (for eg. CC=icc)
To build your project
- select Project > Build Project from main Menu bar.
- To execute, select Run > Run As > C Local application
HTH,
CP
try these steps -
HTH,
CP
