Hi all.
I've been trying to use OpenMP with ICPC (VS 2008).
There is no problem with no-optimization. But the program fails to run (runtime error) with "any" optimization setting.
Is it correct that no optimization option is used with OpenMP directives ?
My system contains Intel i7(Nehalem) 920 processor. And os is Windows 7 (x64)
(Program is also compiled in x64).
11.1 (054)
flags used to compile the code :
/c /O2 /I "C:\Program Files (x86)\Intel\Compiler\11.1\054\MKL\Include" /I "C:\Program Files (x86)\Intel\Compiler\11.1\054\MKL\Include\fftw" /I "C:\Program Files (x86)\Intel\Compiler\11.1\054\IPP\em64t\Include" /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "NOMINMAX" /D "_VC80_UPGRADE=0x0710" /D "_MBCS" /EHsc /MD /GS /fp:fast /Fo"x64\release/" /W3 /nologo /Wp64 /Zi /Qopenmp
This code works well with optimization option (Full-optimization)
[cpp]omp_set_num_threads(4);
int i,j,k;
#pragma omp parallel
#pragma omp for private(i)
for(i=1;i<=grid.m;i++){
for(j=1;j<=grid.n;j++){
for(k=1;k<=grid.mn;k++){
TV_INT index(i,j,k);TV location=grid.Node(i,j,k);
mls_phi_field(index)=mls.Get_Scalar(location);
}[/cpp]
[cpp]omp_set_num_threads(4); #pragma omp parallel { #pragma omp single { for(CELL_ITERATOR iterator(grid);iterator.Valid();iterator.Next()){ #pragma omp task firstprivate(iterator) { TV location=iterator.Location();TV_INT index=iterator.Cell_Index(); mls_phi_field(index)=mls.Get_Scalar(location); } } } }[/cpp]
I'm really sorry. I just try to "reply" to your post. But your post has been deleted !!! Why this happened ?
Anyway, My answer is ...
ICPC 11.1 (054)
I think the problem caused by "iterator" implementation like std container iterator.
Anything I keep in mind when writing the code ?
The first code fragment is wrong. The variables j and k are shared amongst all threads, which is propably not what you indented. You should add a private(j,k) to the parallel construct to ensure that each thread receives a private loop counter for the two inner-most loops.
In the second example, I would assume that you'd be better off in storing location and index not in task scope but in the scope before the task construct. Though I cannot look into the iterator, I would assume that the iterator contains some shared data that is not privatized by firstprivate.
Cheers
-michael
