I have a code that I can compile and run under Centos 7 (parallel studio XE 2016 with odeint-v2 from boost 1.59.0). However, the same code gives me tons of error messages under fedora 22.
void GABAB::compCumSum(double* out,double T_in,double dur) { double dt=0.01; int NStep=(int) floor(dur/dt); int tmpstartInd=startInd; startInd=0; StateVector x(2 * NState); compInitState(x, 0.0, 0.0); for (int ii = 0; ii < NState; ii++) x[ ii + NState ] = 0.0; for (int ii = 0; ii < NState; ii++) out[ii] = x[ii]; setInput(T_in, T_in); cumsum_GABAB tmp(*this); size_t steps = integrate_adaptive( tmp , x , 0.0 , dur , dt ); for (int ii = 0; ii < NState; ii++) out[ii] = x[ii + NState]; startInd=tmpstartInd; }
StateVector is defined in a separate header as:
typedef boost::numeric::ublas::vector< double > StateVector;
When I compile this code under fedora 22, I have the following errors:
icpc -DMKL_ILP64 -il64 -qopenmp -restrict -O2 -std=c++11 -D__TBB_MIC_OFFLOAD=0 -I/opt/intel/mkl/include -I/opt/applications/boost/include -D__ONLYONMIC=0 -DCType=1 -w -c GABAB.cpp -o ../bin/obj/GABAB.o
/usr/include/c++/5.1.1/functional(78): error: class "boost::numeric::odeint::controlled_runge_kutta<boost::numeric::odeint::runge_kutta_dopri5<StateVector, double, StateVector, double, boost::numeric::odeint::vector_space_algebra, boost::numeric::odeint::default_operations, boost::numeric::odeint::initially_resizer>, boost::numeric::odeint::default_error_checker<double, boost::numeric::odeint::vector_space_algebra, boost::numeric::odeint::default_operations>,
boost::numeric::odeint::initially_resizer, boost::numeric::odeint::explicit_error_stepper_fsal_tag>" has no member "result_type"
{ typedef typename _Functor::result_type result_type; };
detected during:
(I cut the output of the compilation to have a "short" topic. If needed, I can provide the full output)
Again, the same code, with the same installation process (of boost and intel cluster studio) works fine under centos 7. Finally, if I remove the -std=c++11 flag, I do not have any error. This is an OK workaround for now but I would like to go back to c++11. I first posted a message on the ODEINT GitHub forum and apparently this could be related to the compiler.
Any clue to what could generate these errors?
Thank you very much,
Pierre
I realized that this is a known issue with c++11 headers.
I'll update the post when the fix will be available...
Pierre
Yes, thanks Pierre for the update. -Kittur
