When I debug a program with single step, I can not debug into
some functions. For example, when I press F11 to step into the function A, it enters into another function B, but in fact the instructions in B are not executed.
How should I solve this problem?
Which debugger do you use? Is it only happening when you compile the source with Intel Compiler? Did you try the tool-bar button?
I saw this once with the Fortran code. But you're using the C++, right?
Jennifer
Please verify that the function you're attempting to step into has been compiled with Debugging symbols (i.e /Zi on Windows and -g on Linux). This is essential for correct Debugger behavior.
System and language run-time libraries are often not compiled with Debugging symbols.
You may also want to check your optimization levels. Not all Debuggers fully support Debugging optimized code.
-- Gordon
