I use Fedora Core 1. When installing Intel C++ compiler, I got the following error. How can I solve it? By the way, I remember that I could install the earlier version of Intel C++ compiler on Redhat 9. Here's the following error:
What rpm install options would you like? [-U --replacefiles]
-U --replacefiles
--------------------------------------------------------------------------------Substitute Headers for Intel C++ Compiler for 32-bit applications, Version 8.0
Installing...
install.sh: line 908: 3113 Segmentation fault rpm $OPTIONS $PREFIX $CHOSENRPM >&$TEMPFILE.rpmout
Installation failed.
--------------------------------------------------------------------------------Intel C++ Compiler for 32-bit applications, Version 8.0
Installing...
install.sh: line 908: 3123 Segmentation fault rpm $OPTIONS $PREFIX $CHOSENRPM >&$TEMPFILE.rpmout
-U --replacefiles
Installing...
Installing...
I got the same message as you. A workaround might be to install the RPM directly without using the install script (as I did) but then you cannot choose installation directory, etc.
Fernando
Fernando
To run the installation scripts, you do need to be a root user. Please also verify the supported kernel/glib versions in the Intel C++ Compiler's ReleaseNotes.
There's a FAQ on our website on how to install the compiler manually at http://support.intel.com/support/performancetools/c/linux/sb/CS-007711.htm.
Jennifer
