Recently downloaded an evaluation copy of parallel studio xe 2015. I have a server running Redhat Linux 6.6 with 2 MIC cards and have (successfully, I think, install mpss 3.4.1.
I am trying to compile sample code in <install dir>/composerxe/Samples/en_US/C++/mic_samples/intro_sampleC with `make mic' and get the error:
sampleC00.c(29): catastrophic error: cannot open source file "offload.h"
#include <offload.h>
Pretty clear I've munged the install. Any suggestions as to problem would be greatly appreciated. Note that I have sourced the `compilervars.csh' file and it appears to have successfully set my path...
Tom
- « Previous
- Next »
Tom, BTW although you have a workaround the issue will be fixed by our developers and I'll update this post as soon the release with the fix is out, thanks much
Kittur, excellent. Thanks again for all your help.
- « Previous
- Next »
