I can compile and link my program correctly with version 2011_sp1_update3, but failed with version 2013_update1.
My program contains only 2 .cpp files, and generated by following 3 commands.
icpc -O3 -inline-level=2 -parallel -ipp=common -mkl=parallel -I/opt/intel/ipp/include -ansi-alias -Wcheck -openmp-report2 -par_report1 -vec-report1 -Wstrict-aliasing -MMD -MP -MF"src/KTiming.d" -MT"src/KTiming.d" -c -o "src/KTiming.o" "../src/KTiming.cpp"
icpc -O3 -inline-level=2 -parallel -ipp=common -mkl=parallel -I/opt/intel/ipp/include -ansi-alias -Wcheck -openmp-report2 -par_report1 -vec-report1 -Wstrict-aliasing -MMD -MP -MF"src/smlab-bbrbm-sp.d" -MT"src/smlab-bbrbm-sp.d" -c -o "src/smlab-bbrbm-sp.o" "../src/smlab-bbrbm-sp.cpp"
icpc -parallel -ipp=common -mkl=parallel -O3 -static-intel -o "smlab-bbrbm-sp" ./src/KTiming.o ./src/smlab-bbrbm-sp.o
When using 2011_sp1_up3, everything is fine. When using 2013, the last link command fails unless I remove the option '-static-intel'.
I use non-commercial license. The OS is CentOS 6.3.
Is this a bug? Is there a way I can link MKL statically?
Thanks!
You should be able to link statically by moving the -mkl switch after your source and object files.
We'll look into making this unnecessary.
