I work on two projects one in VB.NET and one in C++.
I have Microsoft Visual Studio Professional 2013, which I use for the VB project, and Codelite with the GNU C++ compiler, which I use for the C++ project. For various reasons, I want to keep the C++ project free of Microsoft-specific influences.
I wanted to try the Intel C++ compiler, so I downloaded the trial version of "Intel® Parallel Studio XE for Windows" and installed it, and there are now signs of the presence of Intel C++ in VS 2013, but I can't start an Intel C++ project because VS defaults to Microsoft C++.
How do I get round this?
The Intel installer should find your VS installation and suggest integration into it. A VS project would still default to Microsoft but the option of switching between Intel and Microsoft C++ ought to be available at the top of the screen once you open a project. As there is sharing of Microsoft tools, headers, and libraries, there's a lot of visible Microsoft influence.
Thank you Tim.
It did not strike me to create a Visual C++ project and then change the compiler.
The change is at "<right click on project in Solution Explorer>/Intel Composer XE 2013 SP1/Use Intel C++"
Happy Easter,
Jeff
