Intel® C++ Compiler
Can't use std::make_tuple + std::unique_ptr with Intel compiler
Alexander_V_1
Hello.
My compiler version is: Intel Composer XE 2013 SP1 14.0.0 20130728
I can't compile succesfully this code:
#include <tuple>
#include <memory>
int main()
    auto a = std::make_tuple(std::unique_ptr<char>(new char), 0);
    return 0;
Command line is:
icpc tmp.cpp -gcc-name=gcc-4.7 -std=gnu++11 -lstdc++
Error message:
/usr/include/c++/4.7/type_traits(1251): error: function "std::unique_ptr<_Tp, _Dp>::unique_ptr(const std::unique_ptr<_Tp, _Dp> &) [with _Tp=char, _Dp=std::default_delete<char>]" (declared at line 262 of "/usr/include/c++/4.7/bits/unique_ptr.h") cannot be referenced -- it is a deleted function
          static decltype(__test_aux<_To1>(std::declval<_From1>()), __one())
          detected during:
            instantiation of "std::__is_convertible_helper<_From, _To, false>::__test [with _From=const std::unique_ptr<char, std::default_delete<char>> &, _To=std::unique_ptr<char, std::default_delete<char>>]" based on template arguments <const std::unique_ptr<char, std::default_delete<char>> &, std::unique_ptr<char, std::default_delete<char>>> at line 1258
            instantiation of class "std::__is_convertible_helper<_From, _To, false> [with _From=const std::unique_ptr<char, std::default_delete<char>> &, _To=std::unique_ptr<char, std::default_delete<char>>]" at line 1265
            instantiation of class "std::is_convertible<_From, _To> [with _From=const std::unique_ptr<char, std::default_delete<char>> &, _To=std::unique_ptr<char, std::default_delete<char>>]" at line 117
            instantiation of class "std::__and_<_B1, _B2> [with _B1=std::is_convertible<const std::unique_ptr<char, std::default_delete<char>> &, std::unique_ptr<char, std::default_delete<char>>>, _B2=std::is_convertible<const int &, int>]" at line 848 of "/usr/include/c++/4.7/tuple"
            instantiation of "std::tuple<std::__decay_and_strip<_Elements>::__type...> std::make_tuple(_Elements &&...) [with _Elements=<std::unique_ptr<char, std::default_delete<char>>, int>]" at line 9 of "tmp.cpp"
compilation aborted for tmp.cpp (code 2)
What's wrong? If I'm compile it by the GCC compiler, there are no errors.
Alexander_V_1
I'm sorry I forgot to tell about the OS and GCC version.
I'm using Linux Debian 7 (3.2.0-4-amd64) and GCC 4.7.2
Alexander_V_1
I'm sorry, Is it really unsolvable problem and nobody can to help me?
Judith_W_Intel
Thanks for reporting this. I can reproduce this with 14.0 but it looks to be fixed in our development compiler. I have recorded this in our bug tracking database as DPD200248341. We will try to backport the fix into 14.0 for you.
Judy
Alexander_V_1
Thank you for the fix
