Intel® C++ Compiler
Can we change the Code Coverage Result generated by codecov to some other formate like EMMA formate
Rahul_K_2
Can we change the Code Coverage Result generated by codecov to some other formate like EMMA formate ??
JenniferJ
Correctly, I don't think so.
But please provide more info on the EMMA format. why do you prefer that?
Jennifer
jimdempseyatthecove
Rahul_K_2
Hi Jennifer,
EMMA is a toolkit for measuring and reporting Java code coverage.
I have done the code coverage of my Java Code in EMMA and want to do the coverage of my CPP in EMMA format. Since i have done the code coverage of my CPP using codecov so want to convert the report format from codecov format to EMMA format.
SergeyKostrov
Valued Contributor II
Hi Rahul, >>...I have done the code coverage of my Java Code in EMMA... Since you've done that and know internals of EMMA format you need to create a new converter implemented in Java, C/C++, C# or another high level language. Sorry for my generic response.
