we can write program in visual studio 6.0,and compiler them with command line and add /Qopenmp if the program contains Openmp directive clauses,however ,some progam had writen in viusal studio 6.0 and used MFC classes, I want to parallel this progam and add some Openmp directive clauses, I want to compiler this program in visual studio 6.0 not the commad line,how can I do that now ?thanks
Hello, you should select Intel Compiler in VS6.0 and add option /Qopenmp in Project Settings, C/C++ tab, Project Options edit box.
Vladimir
