I'm trying to compile openmpi 1.4.5, but the configuration unfortunately fails with many errors:
configure:7501: icc -E conftest.c
configure:7508: $? = 0
configure:7539: icc -E conftest.c
conftest.c(49): error #2379: cannot open source file "ac_nonexistent.h"
#include
configure:10344: result: -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict
configure:10363: checking for Interix environment
configure:10388: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(58): catastrophic error: #error directive: Normal Unix environment
#error Normal Unix environment
compilation aborted for conftest.c (code 4)
| main ()
| #if !defined(__INTERIX)
| #endif
| return 0;
configure:11522: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:11529: $? = 0
configure:11556: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(102): error: expected an expression
if (sizeof ((long long)))
configure:11625: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:11632: $? = 0
configure:11659: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(103): error: expected an expression
if (sizeof ((long double)))
configure:11728: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:11735: $? = 0
configure:11762: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(104): error: expected an expression
if (sizeof ((int8_t)))
configure:11831: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:11838: $? = 0
configure:11865: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(105): error: expected an expression
if (sizeof ((uint8_t)))
configure:11934: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:11941: $? = 0
configure:11968: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(106): error: expected an expression
if (sizeof ((int16_t)))
configure:12037: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12044: $? = 0
configure:12071: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(107): error: expected an expression
if (sizeof ((uint16_t)))
configure:12140: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12147: $? = 0
configure:12174: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(108): error: expected an expression
if (sizeof ((int32_t)))
configure:12243: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12250: $? = 0
configure:12277: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(109): error: expected an expression
if (sizeof ((uint32_t)))
configure:12346: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12353: $? = 0
configure:12380: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(110): error: expected an expression
if (sizeof ((int64_t)))
configure:12449: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12456: $? = 0
configure:12483: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(111): error: expected an expression
if (sizeof ((uint64_t)))
configure:12552: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12559: $? = 0
configure:12586: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(112): error: expected an expression
if (sizeof ((intptr_t)))
configure:12655: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12662: $? = 0
configure:12689: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(113): error: expected an expression
if (sizeof ((uintptr_t)))
configure:12758: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12765: $? = 0
configure:12792: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(114): error: expected an expression
if (sizeof ((mode_t)))
configure:12861: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12868: $? = 0
configure:12895: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(115): error: expected an expression
if (sizeof ((ssize_t)))
configure:12964: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
configure:12971: $? = 0
configure:12998: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(116): error: expected an expression
if (sizeof ((ptrdiff_t)))
configure:21848: result: 8
configure:21865: checking for C bool type
configure:21889: icc -c -O3 -DNDEBUG -finline-functions -fno-strict-aliasing -restrict conftest.c >&5
conftest.c(140): error: identifier "bool" is undefined
bool bar, foo = true; bar = foo;
conftest.c(140): error: identifier "true" is undefined
configure:21915: result: no
configure:21943: checking for inline
configure:21969: icc -c -O3 -DNDEBUG -Werror -ansi conftest.c >&5
conftest.c(106): error: identifier "inline" is undefined
static inline foo_t static_foo () {return 0; }
conftest.c(106): error: "foo_t" has already been declared in the current scope
conftest.c(106): error: expected a ";"
conftest.c(109): error #12: parsing restarts here after previous syntax error
compilation aborted for conftest.c (code 2)
configure:21976: $? = 2
| inline foo_t foo () {return 0; }
| #endif
configure:21976: $? = 0
configure:21994: result: __inline__
configure:22019: checking for C/C++ restrict keyword
configure:22054: icc -c -O3 -DNDEBUG -Werror -ansi conftest.c >&5
configure:22061: $? = 0
configure:22079: result: __restrict
configure:22097: checking for weak symbol support
configure:22128: icc -O3 -DNDEBUG -Werror -ansi -c conftest_weak.c
configure:22135: $? = 0
configure:22145: icc -O3 -DNDEBUG -Werror -ansi conftest.c conftest_weak.o -o conftest
configure:22152: $? = 0
configure:22179: result: yes
configure:22195: checking whether icc-8.1 for EM64T works with variable arguments
configure:23112: icpc -E conftest.cpp
configure:23119: $? = 0
configure:23150: icpc -E conftest.cpp
conftest.cpp(110): error #2379: cannot open source file "ac_nonexistent.h"
#include
configure:23219: icpc -E conftest.cpp
configure:23226: $? = 0
configure:23257: icpc -E conftest.cpp
#include
configure:24647: result: intel
configure:24669: checking if C++ compiler works
configure:24750: icpc -o conftest -DNDEBUG conftest.cpp >&5
/usr/include/c++/4.7.0/ext/atomicity.h(48): error: identifier "__ATOMIC_ACQ_REL" is undefined
{ return __atomic_fetch_add(__mem, __val, __ATOMIC_ACQ_REL); }
/usr/include/c++/4.7.0/ext/atomicity.h(48): error: identifier "__atomic_fetch_add" is undefined
/usr/include/c++/4.7.0/ext/atomicity.h(52): error: identifier "__ATOMIC_ACQ_REL" is undefined
{ __atomic_fetch_add(__mem, __val, __ATOMIC_ACQ_REL); }
/usr/include/c++/4.7.0/ext/atomicity.h(52): error: identifier "__atomic_fetch_add" is undefined
| return 0;
configure:24787: result: no
configure:24801: error: Could not run a simple C++ program. Aborting.
## Cache variables. ##
The configure line that I used in openmpi source directory is
./configure CC=icc CXX=icpc F77=ifort FC=ifort --prefix=/data/install_test/openmpi
My version of icc/icpc/ifort: 12.1.3 20120212
I also use gcc version 4.7.0 (don't know if that's relevant to my problem).
Could you please give me an advice how to compile openmpi with icc?
Thank you very much.
Martin Vymazal
Martin Vymazal
but i want to ask you that if i temporaryly use CXX=g++ replace for CXX=$PATH/icpc, Is all everything still good?
(if you replace CXX=$PATH/icpc, you will setup openmpi 1.4.5)
thanks a lot
thanhwru83@gmail.com
If you are suggesting building mpicc to use icc and mpiCC to use g++, that may work, but few people will have tried it or be able to give advice.
If your aim is to continue using gcc 4.7 along with icc 12.1, you will have to avoid icpc until you are ready to switch to compatible versions (gcc 4.6 with icc 12.1, gcc 4.7 with icc 13.0).
i am sure that i can build OpenMPI 1.4.5 with g++, but when i try to configure OpenMPI1.6 with icpc, all is okei. however, when i make check, some errors are as follow:
make[3]: Entering directory `/home/thanhnt/openmpi-1.6/ompi/debuggers'
CCLD predefined_gap_test
libtool: link: cannot find the library `../../ompi/libmpi.la' or unhandled argument `../../ompi/libmpi.la'
make[3]: *** [predefined_gap_test] Error 1
make[3]: Leaving directory `/home/thanhnt/openmpi-1.6/ompi/debuggers'
make[2]: *** [check-am] Error 2
make[2]: Leaving directory `/home/thanhnt/openmpi-1.6/ompi/debuggers'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/home/thanhnt/openmpi-1.6/ompi'
make: *** [check-recursive] Error
please tell me that why?
thanks for all
