I want to use Intel complier within a cmake configured project. To achieve this, I am planning to use ICProjConvert but I cannot locate this executable on my system.
I have been searching executable under folder which has path:
C:\Program Files (x86)\Intel\Composer XE 2013 SP1
Could you please help on this issue?
Regards.
You may want to read below article:
https://software.intel.com/en-us/articles/ICProjConvert100
it should be in "<common files>\Intel\Shared Files\ia32\Bin" folder.
(common files, may be: C:\Program Files (x86)\Common Files or C:\Program Files\Common Files, check your system accordingly).
By the way, this tools is used to convert project from VS to Intel compiler, I am not sure whether it works for your case (cmake project?). You may have a try first.
Shenghong
Thank you so much. I couldn't locate <common_files>, now I've found appropriate file.
Cmake outputs a visual studio solution and then I think I can convert that project to an icproj.
Thank you so much for your considerable help.
Hi Engin,
Welcome. :) It will work if it is a visual studio solution.
Shenghong
