Hello, which Parallel Studio SP1 update is compatible with my Centos OS 6.5. I tried to download Sp1 update 4 but the install says my OS is not supported. I was not able to find XE dedicated forum to post it
Hi Andrew,
The XE 2013 SP1 version update 5 is the latest but both update 4 and update 5 contain the compiler version 14.0.4 version and should support RH EL* 5, 6, 7. So, although Cent OS is not officially supported it should still be equivalent with RH EL* versions and should work. So, if the install is failing then you'll need to attach the install log files (found under /tmp/intel*pset*.log) so the install team can investigate the issue.
BTW, the latest Parallel Studio XE 2015 version (not SP1) contains the latest compiler version 15.0 update 2 unlike the 14.0 version you find in SP1, just fyi.
_Kittur
Hi Andrew,
Did my previous communication/suggestions help? Appreciate if you could let me know, thanks
_Kittur
Yes it solved my issue. thank you
Great, thanks for letting me know it's resolved, Andrei
_Kittur
How to get the driver of Intel Wireless 7265 for Centos?Thanks
I am a 840G2 User. I want to get the driver for using it ini centos6.5.
Aleksandro S. wrote:you may not get satisfactory replies by tagging on an unrelated thread. You would look for linux or redhat driver for your device.
Hi Andrew,
This is the compiler C++ forum and as such is not the correct forum for your question on the driver. Try Tim's suggestion, thanks
_Kittur
