Intel® C++ Compiler
Centos support
andrei_k_
Hello, which Parallel Studio SP1 update is compatible with my Centos OS 6.5. I tried to download Sp1 update 4 but the install says my OS is not supported. I was not able to find XE dedicated forum to post it
Kittur_G_Intel
Hi Andrew,
The XE 2013 SP1 version update 5 is the latest but both update 4 and update 5 contain the compiler version 14.0.4 version and should support RH EL* 5, 6, 7. So, although Cent OS is not officially supported it should still be equivalent with RH EL* versions and should work. So, if the install is failing then you'll need to attach the install log files (found under /tmp/intel*pset*.log) so the install team can investigate the issue.
BTW, the latest Parallel Studio XE 2015 version (not SP1) contains the latest compiler version 15.0 update 2 unlike the 14.0 version you find in SP1, just fyi.
_Kittur
Kittur_G_Intel
Hi Andrew,
Did my previous communication/suggestions help? Appreciate if you could let me know, thanks
_Kittur
andrei_k_
Yes it solved my issue. thank you
Kittur_G_Intel
Great, thanks for letting me know it's resolved, Andrei
_Kittur
Aleksandro_S_
How to get the driver of Intel Wireless 7265 for Centos?Thanks
I am a 840G2 User. I want to get the driver for using it ini centos6.5.
TimP
Black Belt
you may not get satisfactory replies by tagging on an unrelated thread. You would look for linux or redhat driver for your device.
Kittur_G_Intel
Hi Andrew,
This is the compiler C++ forum and as such is not the correct forum for your question on the driver. Try Tim's suggestion, thanks
_Kittur
