I have read that the C++-compiler does not support all header files in VC7 (e.g. atlplus.h). Now I however wish to compile a project which unfortunately needs this header. Is it not possible to build projects with these headers using the Intel compiler? Or, is it possible to circumvent this somehow?
Regards Adamcool
Regards Adamcool
The Intel C++ Compiler for Windows doesn't support the new feature "Attribute" that is in some of the header files of VC.NET.
I found one attribute in the "atlplus.h". You could try to common it out and see if it's ok with MS VC compiler. Other than that I don't see any other choices. Sorry.
Jennifer
Jennifer
Thanks for the reply Jennifer.
The project was not very large so I decided to make a new project without attributes and copied the functionality to the new project. Now it works!
Adamcool
Adamcool
Is Intel C++ Compiler for Windows support the feature "Attribute" ("Managed C++") now?
If not, is "Managed C++" support planned for future?
Sorry, both features are not supported still.
Could you file a feature request at PremierSupport https://premier.intel.com/?
Jennifer
