I'm trying to use the code coverage tool to instrument a library with which the application is linked dynamically (.so on linux/ia64). What I have tried is this:
- Compile the library using "icc -prof_genx"
- Compile the application using "icc -prof_genx"
- Run the application, then profmerge.
- Run codecov with the .spi file from the library build, and the .dpi generated from the application.
Is it possible to use the code coverage tool to instrument a dynamic library? What would be the correct procedure for this?
