Intel® C++ Compiler
Code fails to compile
askoufyin
The following code fails to compile with diagnostic message
test.cpp
test.cpp(13): error: incomplete type is not allowed
T items[T_NUMITEMS];
detected during instantiation of class TypeAllocator [with T=Foo, T_NUMITEMS=64U]" at line 81
What am I doing wrong and why compiler thinks that Foo class is incomplete type?
Compiler version 11.1 build 20090930
[cpp]#include
#include
#define FOO_PAGE_SIZE 64
template
class TypeAllocator {
protected:
    typedef struct _s_typeblk {
        struct _s_typeblk *next;
    } _TypeBlock;
protected:
    _TypeBlock *_head;
    T *_free;
protected:
    T *setupFreeChain(_TypeBlock *blk) {
        int i;
        for(i=T_NUMITEMS-1; i>0; --i)
            *reinterpret_cast(&blk->items[i-1]) = &blk->items;
        *reinterpret_cast(&blk->items[T_NUMITEMS-1]) = NULL;
        return blk->items;
public:
    TypeAllocator(): _head(0), _free(0) {
    ~TypeAllocator() {
        _TypeBlock *temp;
        while(_head) {
            temp = _head;
            _head = _head->next;
            ::free(temp);
    T *alloc() {
        _TypeBlock *nb;
        T *item;
        if(!_free) {
            if((nb = (_TypeBlock *)::malloc(sizeof(_TypeBlock)))==NULL)
                return NULL;
            nb->next = _head;
            _head = nb;
            _free = setupFreeChain(nb);
        item = _free;
        _free = *reinterpret_cast(_free);
        return item;
    void free(T *ptr) {
        _TypeBlock *blk;
        for(blk=_head; blk; blk=blk->next)
            if(ptr >= blk->items && ptr <= &blk->items[T_NUMITEMS-1])
                break;
        if(blk) {
            *reinterpret_cast(ptr) = _free;
            _free = ptr;
class Foo
protected:
    static TypeAllocator allocator;
public:
    void *operator new(size_t cb) {
          return (void *)allocator.alloc();
    void operator delete(void *ptr, size_t cb) {
          allocator.free((Foo *)ptr);
TypeAllocator Foo::allocator;
int main()
    Foo *foo = new Foo();
    delete foo;
[/cpp]
JenniferJ
Thanks for attaching a testcase.
It seems a compiler bug to me. VC2008 compiles fine. I'll file a bug report to the compiler engineer team and will let you know if there's a work-around or any progress.
Thanks again!
Jennifer
JenniferJ
Our engineer found a work-around for this case.
Please move the struct-type to the outside of the class template like following:
[cpp]#include
#include
template
struct _s_typeblk {
        M items[M_SIZE];
template
protected:
	typedef _s_typeblk _TypeBlock;
protected:
    _TypeBlock *_head;
    T *_free;
protected:
        int i;
        return blk->items;
public:
    ~TypeAllocator() {
        _TypeBlock *temp;
        while(_head) {
            temp = _head;
            ::free(temp);
    T *alloc() {
        _TypeBlock *nb;
        T *item;
        if(!_free) {
                return NULL;
            nb->next = _head;
            _head = nb;
        item = _free;
        return item;
    void free(T *ptr) {
        _TypeBlock *blk;
                break;
        if(blk) {
            _free = ptr;
class Foo
protected:
public:
int main()
    delete foo;
[/cpp]
askoufyin
Thank you very much! It works as intended now.
