Intel® C++ Compiler
7873 Discussions
Codecov exclude folders and ignore system functions
herenkeskin
I'm using codecov but i have 2 question.
1) I can't exclude folders with "-comp" tag, i can't add all files file by file. How can i solve this problem?
2) I can't ignore system functions from output. I don't want to see "std" functions to my output file. What can i do?
Gopika_Intel
Hi
Thank you for posting your query in Intel C++ Compiler forum. Could you please provide us with the following details so that we can try it from our end.
1.    Folder structure(zip format)
2.    A minimal reproducer code
3.    Steps followed to reproduce it
Gopika
herenkeskin
Hi, thanks for your answer but i can't share my structure with you, it is a private project and we used GCC now. We want to change compiler to ICC. At the moment we are trying ICC's skills and code coverage is important for us.
I'm using this command:
"codecov -prj main -dpi pgopti.dpi -spi pgopti.spi -comp comp.txt"
And these lines are added in comp.txt file:
~lib/
~tools/
~test/
~gmock
common/
core/
src/
This file solve my second problem but not enough.
Can i see conditional coverage and line coverage (not block)? Does codecov have these options?
And how can i convert codecov output to Cobertura XML format? I tried Halvorlu's script which is codecov-to-cobertura but it isn't good. If we can't convert Cobertura XML format, how can we used this coverage report in Jenkins?
Thanks for your answer.
herenkeskin
Hi Viet,
Thanks for your answer, but i wrote all document. My solution is not in there.
Viet_H_Intel
Would you summarize your questions/concerns again because I am a bit confused as you said you had some issues with -comp, then later said -comp solved your second issue but not enough.
Viet_H_Intel
If this is still an issue can you summarize what you want us to address?
Viet_H_Intel
We haven't heard back from you and so won't monitor this thread. Any further updates would be considered community. If you need further assistance, please create a new thread.
