We are using the code coverage flag to compile our C++ code using "-prof-gen=srcpos" flag. The profmerge is fine and generating the .dpi file but when I try to generate the HTML report it fails with following error.
Intel C++/Fortran Compiler code-coverage tool for applications running on IA-32, Version 11.1 Build 20100203 Package ID: l_cproc_p_11.1.069
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
Segmentation violation
Attached is the .dpi file.
Any help will be useful.
It would be nice if you can attach a test case to reproduce the issue.
