Intel® C++ Compiler
7956 Discussions
Command-line error: old for-init compatibility mode cannot be used with C++11 mode
Grant_S_
Having trouble with the error message
We are moving an existing application compiled for win32 on an XP box with ver 11.1.067 to win10 with ver 2017.1.143
The icproj file copied across and converted on opening - apparently sucessfully
but NOTHING will compile - we just get the above error message.
Any assistance would be appreciated
=G=
Grant_S_
Also, the C++11 option was turned off
G
Melanie_B_Intel
This diagnostic is given for the /Zc:forScope command line option.  Refer to the msdn page for details about the option: https://msdn.microsoft.com/en-us/library/84wcsx8x.aspx
The remedy is to remove the command line option.  Hope this helps.
--Melanie
TimP
I've seen this old Microsoft extension used in the context of break.  It becomes impossible to know whether a variable takes outer or inner scope.  If you have not in fact used a variable defined inside the for after leaving the for scope, a working example of your problem would be needed.
