I installed the latest Intel C compiler on a Linux machine.
I tried to build 32bit/64bit binaries to compare them with gcc-produced binaries.
However, Intel C compiler emits abort message when I try to compile 32bit coreutils.
I just added '-m32' option to config file.
(gcc compiler successfully generates 32bit binary with same option.)
I cannot figure out why compilation is aborted?
I add an error message as follows:
CC lib/openat-die.o
CC lib/openat-safer.o
CC lib/parse-datetime.o
parse-datetime.y(308) (col. 12): internal error: 04010002_1870
compilation aborted for ../../../coreutils-8.30/lib/parse-datetime.c (code 4)
Makefile:9142: recipe for target 'lib/parse-datetime.o' failed
make[2]: *** [lib/parse-datetime.o] Error 4
Machine: ubuntu-18.04 64-bit
ICC version: v19.1.2.254
Binary: coreutils-8.30
It looks like a bug to me.
Could you please send the pre-processed file for parse-datetime.c (parse-datetime.i) or the minimal reproducible source file that is causing the error?
Is the 64-bit version of the same source file compilable with icc?
Rahul
Thank you for your reply.
I added '-save-temps' option into a Makefile but Intel C Compiler does not emit pre-processed file.
I read following document and I guess ICC removes the pre-processed file right after generating assembly file.
How can I produce pre-processed file?
Instead I post relevant source code as follows
Can you look into your build log file (assume there is one), see how parse-datetime.c was compiled. Then replace -c with -E, remove -o parse-datetime.o and capture the output. That should give you a parse-datetime.i.
Thank you for your advise.
I simplify error code as follows.
static bool
apply_relative_time (parser_control *pc, relative_time rel, int factor)
int a = INT_ADD_WRAPV (pc->rel.ns, rel.ns, &pc->rel.ns)
| INT_ADD_WRAPV (pc->rel.seconds, rel.seconds, &pc->rel.seconds);
if (factor < 0
? (INT_SUBTRACT_WRAPV (pc->rel.ns, rel.ns, &pc->rel.ns)
| INT_SUBTRACT_WRAPV (pc->rel.seconds, rel.seconds, &pc->rel.seconds)
| INT_SUBTRACT_WRAPV (pc->rel.minutes, rel.minutes, &pc->rel.minutes)
| INT_SUBTRACT_WRAPV (pc->rel.hour, rel.hour, &pc->rel.hour)
| INT_SUBTRACT_WRAPV (pc->rel.day, rel.day, &pc->rel.day)
| INT_SUBTRACT_WRAPV (pc->rel.month, rel.month, &pc->rel.month)
| INT_SUBTRACT_WRAPV (pc->rel.year, rel.year, &pc->rel.year))
: (INT_ADD_WRAPV (pc->rel.ns, rel.ns, &pc->rel.ns)
| INT_ADD_WRAPV (pc->rel.minutes, rel.minutes, &pc->rel.minutes)
| INT_ADD_WRAPV (pc->rel.hour, rel.hour, &pc->rel.hour)
| INT_ADD_WRAPV (pc->rel.day, rel.day, &pc->rel.day)
| INT_ADD_WRAPV (pc->rel.month, rel.month, &pc->rel.month)
| INT_ADD_WRAPV (pc->rel.year, rel.year, &pc->rel.year)))
return false;
pc->rels_seen = true;
return true;
And this is the relevant code in the preprocessed file.
int a = (sizeof *(&pc->rel . ns) == sizeof (signed char) ? (sizeof ((pc->rel . ns) + (rel . ns)) < sizeof (signed char) ? ((__builtin_add_overflow_p ((signed char) (pc->rel . ns), (signed char) (rel . ns), (__typeof__ (((signed char) (pc->rel . ns)) + ((signed char) (rel . ns)))) 0) || (((0 * (((signed char) (pc->rel . ns)) + ((signed char) (rel . ns))) - (1)) < 0) && (((signed char) (pc->rel . ns)) + ((signed char) (rel . ns))) < ((-127-1))) || (127) < (((signed char) (pc->rel . ns)) + ((signed char) (rel . ns)))) ? (*(&pc->rel . ns) = ((signed char) ((unsigned int) ((signed char) (pc->rel . ns)) + (unsigned int) ((signed char) (rel . ns)))), 1) : (*(&pc->rel . ns) = ((signed char) ((unsigned int) ((signed char) (pc->rel . ns)) + (unsigned int) ((signed char) (rel . ns)))), 0)) : ((__builtin_add_overflow_p (pc->rel . ns, rel . ns, (__typeof__ ((pc->rel . ns) + (rel . ns))) 0) || (((0 * ((pc->rel . ns) + (rel . ns)) - (1)) < 0) && ((pc->rel . ns) + (rel . ns)) < ((-127-1))) || (127) < ((pc->rel . ns) + (rel . ns))) ? (*(&pc->rel . ns) = ((signed char) ((unsigned int) (pc->rel . ns) + (unsigned int) (rel . ns))), 1) : (*(&pc->rel . ns) = ((signed char) ((unsigned int) (pc->rel . ns) + (unsigned int) (rel . ns))), 0))) : sizeof *(&pc->rel . ns) == sizeof (short int) ? (sizeof ((pc->rel . ns) + (rel . ns)) < sizeof (short int) ? ((__builtin_add_overflow_p ((short int) (pc->rel . ns), (short int) (rel . ns), (__typeof__ (((short int) (pc->rel . ns)) + ((short int) (rel . ns)))) 0) || (((0 * (((short int) (pc->rel . ns)) + ((short int) (rel . ns))) - (1)) < 0) && (((short int) (pc->rel . ns)) + ((short int) (rel . ns))) < ((-32767 -1))) || (32767) < (((short int) (pc->rel . ns)) + ((short int) (rel . ns)))) ? (*(&pc->rel . ns) = ((short int) ((unsigned int) ((short int) (pc->rel . ns)) + (unsigned int) ((short int) (rel . ns)))), 1) : (*(&pc->rel . ns) = ((short int) ((unsigned int) ((short int) (pc->rel . ns)) + (unsigned int) ((short int) (rel . ns)))), 0)) : ((__builtin_add_overflow_p (pc->rel . ns, rel . ns, (__typeof__ ((pc->rel . ns) + (rel . ns))) 0) || (((0 * ((pc->rel . ns) + (rel . ns)) - (1)) < 0) && ((pc->rel . ns) + (rel . ns)) < ((-32767 -1))) || (32767) < ((pc->rel . ns) + (rel . ns))) ? (*(&pc->rel . ns) = ((short int) ((unsigned int) (pc->rel . ns) + (unsigned int) (rel . ns))), 1) : (*(&pc->rel . ns) = ((short int) ((unsigned int) (pc->rel . ns) + (unsigned int) (rel . ns))), 0))) : sizeof *(&pc->rel . ns) == sizeof (int) ? (sizeof ((pc->rel . ns) + (rel . ns)) < sizeof (int) ? ((__builtin_add_overflow_p ((int) (pc->rel . ns), (int) (rel . ns), (__typeof__ (((int) (pc->rel . ns)) + ((int) (rel . ns)))) 0) || (((0 * (((int) (pc->rel . ns)) + ((int) (rel . ns))) - (1)) < 0) && (((int) (pc->rel . ns)) + ((int) (rel . ns))) < ((-2147483647 -1))) || (2147483647) < (((int) (pc->rel . ns)) + ((int) (rel . ns)))) ? (*(&pc->rel . ns) = ((int) ((unsigned int) ((int) (pc->rel . ns)) + (unsigned int) ((int) (rel . ns)))), 1) : (*(&pc->rel . ns) = ((int) ((unsigned int) ((int) (pc->rel . ns)) + (unsigned int) ((int) (rel . ns)))), 0)) : ((__builtin_add_overflow_p (pc->rel . ns, rel . ns, (__typeof__ ((pc->rel . ns) + (rel . ns))) 0) || (((0 * ((pc->rel . ns) + (rel . ns)) - (1)) < 0) && ((pc->rel . ns) + (rel . ns)) < ((-2147483647 -1))) || (2147483647) < ((pc->rel . ns) + (rel . ns))) ? (*(&pc->rel . ns) = ((int) ((unsigned int) (pc->rel . ns) + (unsigned int) (rel . ns))), 1) : (*(&pc->rel . ns) = ((int) ((unsigned int) (pc->rel . ns) + (unsigned int) (rel . ns))), 0))) : (sizeof *(&pc->rel . ns) == sizeof (long int) ? (sizeof ((pc->rel . ns) + (rel . ns)) < sizeof (long int) ? ((__builtin_add_overflow_p ((long int) (pc->rel . ns), (long int) (rel . ns), (__typeof__ (((long int) (pc->rel . ns)) + ((long int) (rel . ns)))) 0) || (((0 * (((long int) (pc->rel . ns)) + ((long int) (rel . ns))) - (1)) < 0) && (((long int) (pc->rel . ns)) + ((long int) (rel . ns))) < ((-2147483647 -1L))) || (2147483647) < (((long int) (pc->rel . ns)) + ((long int) (rel . ns)))) ? (*(&pc->rel . ns) = ((long int) ((unsigned long int) ((long int) (pc->rel . ns)) + (unsigned long int) ((long int) (rel . ns)))), 1) : (*(&pc->rel . ns) = ((long int) ((unsigned long int) ((long int) (pc->rel . ns)) + (unsigned long int) ((long int) (rel . ns)))), 0)) : ((__builtin_add_overflow_p (pc->rel . ns, rel . ns, (__typeof__ ((pc->rel . ns) + (rel . ns))) 0) || (((0 * ((pc->rel . ns) + (rel . ns)) - (1)) < 0) && ((pc->rel . ns) + (rel . ns)) < ((-2147483647 -1L))) || (2147483647) < ((pc->rel . ns) + (rel . ns))) ? (*(&pc->rel . ns) = ((long int) ((unsigned long int) (pc->rel . ns) + (unsigned long int) (rel . ns))), 1) : (*(&pc->rel . ns) = ((long int) ((unsigned long int) (pc->rel . ns) + (unsigned long int) (rel . ns))), 0))) : (sizeof ((pc->rel . ns) + (rel . ns)) < sizeof (long long int) ? ((__builtin_add_overflow_p ((long long int) (pc->rel . ns), (long long int) (rel . ns), (__typeof__ (((long long int) (pc->rel . ns)) + ((long long int) (rel . ns)))) 0) || (((0 * (((long long int) (pc->rel . ns)) + ((long long int) (rel . ns))) - (1)) < 0) && (((long long int) (pc->rel . ns)) + ((long long int) (rel . ns))) < ((-0x7fffffffffffffff-1LL))) || (0x7fffffffffffffff) < (((long long int) (pc->rel . ns)) + ((long long int) (rel . ns)))) ? (*(&pc->rel . ns) = ((long long int) ((unsigned long long int) ((long long int) (pc->rel . ns)) + (unsigned long long int) ((long long int) (rel . ns)))), 1) : (*(&pc->rel . ns) = ((long long int) ((unsigned long long int) ((long long int) (pc->rel . ns)) + (unsigned long long int) ((long long int) (rel . ns)))), 0)) : ((__builtin_add_overflow_p (pc->rel . ns, rel . ns, (__typeof__ ((pc->rel . ns) + (rel . ns))) 0) || (((0 * ((pc->rel . ns) + (rel . ns)) - (1)) < 0) && ((pc->rel . ns) + (rel . ns)) < ((-0x7fffffffffffffff-1LL))) || (0x7fffffffffffffff) < ((pc->rel . ns) + (rel . ns))) ? (*(&pc->rel . ns) = ((long long int) ((unsigned long long int) (pc->rel . ns) + (unsigned long long int) (rel . ns))), 1) : (*(&pc->rel . ns) = ((long long int) ((unsigned long long int) (pc->rel . ns) + (unsigned long long int) (rel . ns))), 0)))))
| (sizeof *(&pc->rel . seconds) == sizeof (signed char) ? (sizeof ((pc->rel . seconds) + (rel . seconds)) < sizeof (signed char) ? ((__builtin_add_overflow_p ((signed char) (pc->rel . seconds), (signed char) (rel . seconds), (__typeof__ (((signed char) (pc->rel . seconds)) + ((signed char) (rel . seconds)))) 0) || (((0 * (((signed char) (pc->rel . seconds)) + ((signed char) (rel . seconds))) - (1)) < 0) && (((signed char) (pc->rel . seconds)) + ((signed char) (rel . seconds))) < ((-127-1))) || (127) < (((signed char) (pc->rel . seconds)) + ((signed char) (rel . seconds)))) ? (*(&pc->rel . seconds) = ((signed char) ((unsigned int) ((signed char) (pc->rel . seconds)) + (unsigned int) ((signed char) (rel . seconds)))), 1) : (*(&pc->rel . seconds) = ((signed char) ((unsigned int) ((signed char) (pc->rel . seconds)) + (unsigned int) ((signed char) (rel . seconds)))), 0)) : ((__builtin_add_overflow_p (pc->rel . seconds, rel . seconds, (__typeof__ ((pc->rel . seconds) + (rel . seconds))) 0) || (((0 * ((pc->rel . seconds) + (rel . seconds)) - (1)) < 0) && ((pc->rel . seconds) + (rel . seconds)) < ((-127-1))) || (127) < ((pc->rel . seconds) + (rel . seconds))) ? (*(&pc->rel . seconds) = ((signed char) ((unsigned int) (pc->rel . seconds) + (unsigned int) (rel . seconds))), 1) : (*(&pc->rel . seconds) = ((signed char) ((unsigned int) (pc->rel . seconds) + (unsigned int) (rel . seconds))), 0))) : sizeof *(&pc->rel . seconds) == sizeof (short int) ? (sizeof ((pc->rel . seconds) + (rel . seconds)) < sizeof (short int) ? ((__builtin_add_overflow_p ((short int) (pc->rel . seconds), (short int) (rel . seconds), (__typeof__ (((short int) (pc->rel . seconds)) + ((short int) (rel . seconds)))) 0) || (((0 * (((short int) (pc->rel . seconds)) + ((short int) (rel . seconds))) - (1)) < 0) && (((short int) (pc->rel . seconds)) + ((short int) (rel . seconds))) < ((-32767 -1))) || (32767) < (((short int) (pc->rel . seconds)) + ((short int) (rel . seconds)))) ? (*(&pc->rel . seconds) = ((short int) ((unsigned int) ((short int) (pc->rel . seconds)) + (unsigned int) ((short int) (rel . seconds)))), 1) : (*(&pc->rel . seconds) = ((short int) ((unsigned int) ((short int) (pc->rel . seconds)) + (unsigned int) ((short int) (rel . seconds)))), 0)) : ((__builtin_add_overflow_p (pc->rel . seconds, rel . seconds, (__typeof__ ((pc->rel . seconds) + (rel . seconds))) 0) || (((0 * ((pc->rel . seconds) + (rel . seconds)) - (1)) < 0) && ((pc->rel . seconds) + (rel . seconds)) < ((-32767 -1))) || (32767) < ((pc->rel . seconds) + (rel . seconds))) ? (*(&pc->rel . seconds) = ((short int) ((unsigned int) (pc->rel . seconds) + (unsigned int) (rel . seconds))), 1) : (*(&pc->rel . seconds) = ((short int) ((unsigned int) (pc->rel . seconds) + (unsigned int) (rel . seconds))), 0))) : sizeof *(&pc->rel . seconds) == sizeof (int) ? (sizeof ((pc->rel . seconds) + (rel . seconds)) < sizeof (int) ? ((__builtin_add_overflow_p ((int) (pc->rel . seconds), (int) (rel . seconds), (__typeof__ (((int) (pc->rel . seconds)) + ((int) (rel . seconds)))) 0) || (((0 * (((int) (pc->rel . seconds)) + ((int) (rel . seconds))) - (1)) < 0) && (((int) (pc->rel . seconds)) + ((int) (rel . seconds))) < ((-2147483647 -1))) || (2147483647) < (((int) (pc->rel . seconds)) + ((int) (rel . seconds)))) ? (*(&pc->rel . seconds) = ((int) ((unsigned int) ((int) (pc->rel . seconds)) + (unsigned int) ((int) (rel . seconds)))), 1) : (*(&pc->rel . seconds) = ((int) ((unsigned int) ((int) (pc->rel . seconds)) + (unsigned int) ((int) (rel . seconds)))), 0)) : ((__builtin_add_overflow_p (pc->rel . seconds, rel . seconds, (__typeof__ ((pc->rel . seconds) + (rel . seconds))) 0) || (((0 * ((pc->rel . seconds) + (rel . seconds)) - (1)) < 0) && ((pc->rel . seconds) + (rel . seconds)) < ((-2147483647 -1))) || (2147483647) < ((pc->rel . seconds) + (rel . seconds))) ? (*(&pc->rel . seconds) = ((int) ((unsigned int) (pc->rel . seconds) + (unsigned int) (rel . seconds))), 1) : (*(&pc->rel . seconds) = ((int) ((unsigned int) (pc->rel . seconds) + (unsigned int) (rel . seconds))), 0))) : (sizeof *(&pc->rel . seconds) == sizeof (long int) ? (sizeof ((pc->rel . seconds) + (rel . seconds)) < sizeof (long int) ? ((__builtin_add_overflow_p ((long int) (pc->rel . seconds), (long int) (rel . seconds), (__typeof__ (((long int) (pc->rel . seconds)) + ((long int) (rel . seconds)))) 0) || (((0 * (((long int) (pc->rel . seconds)) + ((long int) (rel . seconds))) - (1)) < 0) && (((long int) (pc->rel . seconds)) + ((long int) (rel . seconds))) < ((-2147483647 -1L))) || (2147483647) < (((long int) (pc->rel . seconds)) + ((long int) (rel . seconds)))) ? (*(&pc->rel . seconds) = ((long int) ((unsigned long int) ((long int) (pc->rel . seconds)) + (unsigned long int) ((long int) (rel . seconds)))), 1) : (*(&pc->rel . seconds) = ((long int) ((unsigned long int) ((long int) (pc->rel . seconds)) + (unsigned long int) ((long int) (rel . seconds)))), 0)) : ((__builtin_add_overflow_p (pc->rel . seconds, rel . seconds, (__typeof__ ((pc->rel . seconds) + (rel . seconds))) 0) || (((0 * ((pc->rel . seconds) + (rel . seconds)) - (1)) < 0) && ((pc->rel . seconds) + (rel . seconds)) < ((-2147483647 -1L))) || (2147483647) < ((pc->rel . seconds) + (rel . seconds))) ? (*(&pc->rel . seconds) = ((long int) ((unsigned long int) (pc->rel . seconds) + (unsigned long int) (rel . seconds))), 1) : (*(&pc->rel . seconds) = ((long int) ((unsigned long int) (pc->rel . seconds) + (unsigned long int) (rel . seconds))), 0))) : (sizeof ((pc->rel . seconds) + (rel . seconds)) < sizeof (long long int) ? ((__builtin_add_overflow_p ((long long int) (pc->rel . seconds), (long long int) (rel . seconds), (__typeof__ (((long long int) (pc->rel . seconds)) + ((long long int) (rel . seconds)))) 0) || (((0 * (((long long int) (pc->rel . seconds)) + ((long long int) (rel . seconds))) - (1)) < 0) && (((long long int) (pc->rel . seconds)) + ((long long int) (rel . seconds))) < ((-0x7fffffffffffffff-1LL))) || (0x7fffffffffffffff) < (((long long int) (pc->rel . seconds)) + ((long long int) (rel . seconds)))) ? (*(&pc->rel . seconds) = ((long long int) ((unsigned long long int) ((long long int) (pc->rel . seconds)) + (unsigned long long int) ((long long int) (rel . seconds)))), 1) : (*(&pc->rel . seconds) = ((long long int) ((unsigned long long int) ((long long int) (pc->rel . seconds)) + (unsigned long long int) ((long long int) (rel . seconds)))), 0)) : ((__builtin_add_overflow_p (pc->rel . seconds, rel . seconds, (__typeof__ ((pc->rel . seconds) + (rel . seconds))) 0) || (((0 * ((pc->rel . seconds) + (rel . seconds)) - (1)) < 0) && ((pc->rel . seconds) + (rel . seconds)) < ((-0x7fffffffffffffff-1LL))) || (0x7fffffffffffffff) < ((pc->rel . seconds) + (rel . seconds))) ? (*(&pc->rel . seconds) = ((long long int) ((unsigned long long int) (pc->rel . seconds) + (unsigned long long int) (rel . seconds))), 1) : (*(&pc->rel . seconds) = ((long long int) ((unsigned long long int) (pc->rel . seconds) + (unsigned long long int) (rel . seconds))), 0)))));
pc->rels_seen = 1;
return 1;
Thank you
We would need to have a completed preprocess file along with your command line options in order to investigate the issue. Thanks
I understand. Thanks.
I attach the pre-processed file and this is my compile option.
Compile Option: icc -I. -I../../../coreutils-8.30 -I./lib -Ilib -I../../../coreutils-8.30/lib -Isrc -I../../../coreutils-8.30/src -m32 -ggdb -save-temps -fverbose-asm -O0 -fPIE -pie -MT lib/parse-datetime.o -MD -MP -MF lib/.deps/parse-datetime.Tpo -E ../../../coreutils-8.30/lib/parse-datetime.c
Thank you.
- Hyungseok
Thanks for the preprocess file. I've reported this bug to our Developer.
Thank you.
I am waiting for the result of error report.
- Hyungseok
It will take sometime before this bug can be fixed.
In the meantime can you add this as a workaround?
long long fake_result;
#define __builtin_add_overflow_p(x,y,z) __builtin_add_overflow(x,y,(typeof(z) *)&fake_result)
Have you tried the workaround? Please let us know if it works for you, then we can close this thread.
We are going to close this thread as we have provided a workaround. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Viet
