Intel® C++ Compiler
7783 Discussions
Compilation error using Intel compiler 2017
shachar-arieli
I am getting the following error while compiling a project using Intel compiler (parallel studio 2017 rev 4)
"old for-init compatibility mode cannot be used with C++11 mode"
The project is compiling fine when using c++ compiler 2015.
Any idea on what i can do to correct this issue?
Melanie_B_Intel
This diagnostic is given for the /Zc:forScope command line option.  Refer to the msdn page for details about the option: https://msdn.microsoft.com/en-us/library/84wcsx8x.aspx
The remedy is to remove the command line option.
--Melanie
Melanie_B_Intel
--Melanie
