Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Compilation error when compiling simple (valid) C++ code
Poletti__Marco
Compiling the following code:
template <typename T>
struct Outer {
  struct Inner {
    template <typename U>
    Outer<U> foo();
Outer<U> Outer<T>::Inner::foo() {
  return {};
Fails to compile with ICC 19.0.0.117, while it should be correct.
GCC and Clang can compile this without issues.
ICC emits the following compilation errors:
main.cpp(10): warning #2357: "Outer<U>" cannot be specified in a template member definition -- "Outer<T>" assumed instead
main.cpp(10): error: declaration is incompatible with function template "Outer<U> Outer<T>::Inner::foo<U>()" (declared at line 5)
compilation aborted for main.cpp (code 2)
Viet_H_Intel
Thanks for report this issue. I've filed a bug with the Developer. The internal case number is CMPLRS-52589.
Viet
