Intel® C++ Compiler
Compilation errors building boost with intel compiler
Charles_G_
Intel compiler version: 16.0
Boost version: 1.60
Mac running 10.11 (El Capitan) on a Macbook Pro with an Intel Core i7 (2011)
I followed the instructions here very closely: https://software.intel.com/en-us/articles/building-boost-with-intel-c-compiler-150 and I get errors like these:
Jamfile</Users/cgreen/software/boost_1_60_0/libs/context/build>.gas64 ../boost_build/boost/bin.v2/libs/context/build/intel-darwin-16.0/release/threading-multi/asm/make_x86_64_sysv_macho_gas.o
clang: error: unsupported option '--64'
clang: error: no input files
    cpp -x assembler-with-cpp "libs/context/src/asm/make_x86_64_sysv_macho_gas.S" | as --64 -o "../boost_build/boost/bin.v2/libs/context/build/intel-darwin-16.0/release/threading-multi/asm/make_x86_64_sysv_macho_gas.o"
...failed Jamfile</Users/cgreen/software/boost_1_60_0/libs/context/build>.gas64 ../boost_build/boost/bin.v2/libs/context/build/intel-darwin-16.0/release/threading-multi/asm/make_x86_64_sysv_macho_gas.o...
Jamfile</Users/cgreen/software/boost_1_60_0/libs/context/build>.gas64 ../boost_build/boost/bin.v2/libs/context/build/intel-darwin-16.0/release/threading-multi/asm/jump_x86_64_sysv_macho_gas.o
    cpp -x assembler-with-cpp "libs/context/src/asm/jump_x86_64_sysv_macho_gas.S" | as --64 -o "../boost_build/boost/bin.v2/libs/context/build/intel-darwin-16.0/release/threading-multi/asm/jump_x86_64_sysv_macho_gas.o"
...failed Jamfile</Users/cgreen/software/boost_1_60_0/libs/context/build>.gas64 ../boost_build/boost/bin.v2/libs/context/build/intel-darwin-16.0/release/threading-multi/asm/jump_x86_64_sysv_macho_gas.o...
common.mkdir ../boost_build/boost/bin.v2/libs/context/build/intel-darwin-16.0/release/threading-multi/posix
And later more errors:
intel-darwin.link.dll ../boost_build/boost/bin.v2/libs/locale/build/intel-darwin-16.0/release/threading-multi/libboost_locale.dylib
Undefined symbols for architecture x86_64:
  "__ZNSt3__110moneypunctIcLb0EED2Ev", referenced from:
      __ZN5boost6locale8impl_std17create_formattingERKNSt3__16localeERKNS2_12basic_stringIcNS2_11char_traitsIcEENS2_9allocatorIcEEEEjNS1_12utf8_supportE in numeric.o
      __ZN5boost6locale8impl_std14create_parsingERKNSt3__16localeERKNS2_12basic_stringIcNS2_11char_traitsIcEENS2_9allocatorIcEEEEjNS1_12utf8_supportE in numeric.o
      __ZN5boost6locale8impl_std25utf8_moneypunct_from_wideILb0EED1Ev in numeric.o
      __ZN5boost6locale8impl_std25utf8_moneypunct_from_wideILb0EED0Ev in numeric.o
      __ZN5boost6locale8impl_std15utf8_moneypunctILb0EED1Ev in numeric.o
      __ZN5boost6locale8impl_std15utf8_moneypunctILb0EED0Ev in numeric.o
      __ZN5boost6locale8impl_std20create_basic_parsingIcEENSt3__16localeERKS4_RKNS3_12basic_stringIcNS3_11char_traitsIcEENS3_9allocatorIcEEEE in numeric.o
  "__ZNSt3__110moneypunctIcLb1EED2Ev", referenced from:
      __ZN5boost6locale8impl_std25utf8_moneypunct_from_wideILb1EED1Ev in numeric.o
      __ZN5boost6locale8impl_std25utf8_moneypunct_from_wideILb1EED0Ev in numeric.o
      __ZN5boost6locale8impl_std15utf8_moneypunctILb1EED1Ev in numeric.o
      __ZN5boost6locale8impl_std15utf8_moneypunctILb1EED0Ev in numeric.o
  "__ZNSt3__110moneypunctIwLb0EED2Ev", referenced from:
      __ZN5boost6locale8impl_std20create_basic_parsingIwEENSt3__16localeERKS4_RKNS3_12basic_stringIcNS3_11char_traitsIcEENS3_9allocatorIcEEEE in numeric.o
  "__ZNSt3__110moneypunctIwLb1EED2Ev", referenced from:
  "__ZNSt3__18time_putIcNS_19ostreambuf_iteratorIcNS_11char_traitsIcEEEEED2Ev", referenced from:
      __ZN5boost6locale10impl_posix14time_put_posixIcED1Ev in numeric.o
      __ZN5boost6locale10impl_posix14time_put_posixIcED0Ev in numeric.o
      __ZN5boost6locale8impl_std23utf8_time_put_from_wideD1Ev in numeric.o
      __ZN5boost6locale8impl_std23utf8_time_put_from_wideD0Ev in numeric.o
      __ZN5boost6locale8impl_std18time_put_from_baseIcED1Ev in numeric.o
      __ZN5boost6locale8impl_std18time_put_from_baseIcED0Ev in numeric.o
  "__ZNSt3__18time_putIwNS_19ostreambuf_iteratorIwNS_11char_traitsIwEEEEED2Ev", referenced from:
      __ZN5boost6locale10impl_posix14time_put_posixIwED1Ev in numeric.o
      __ZN5boost6locale10impl_posix14time_put_posixIwED0Ev in numeric.o
      __ZN5boost6locale8impl_std18time_put_from_baseIwED1Ev in numeric.o
      __ZN5boost6locale8impl_std18time_put_from_baseIwED0Ev in numeric.o
ld: symbol(s) not found for architecture x86_64
Any ideas?
KitturGanesh
Hi Charles,
Just letting you know I'll investigate this and see if I can reproduce the issue so I  can file the issue with the developers. I'll keep you updated right after. Appreciate your patience till then
Kittur
Charles_G_
Kittur
Thanks! I would be fine with using an older version of boost for my application but I get similar errors for boost 1.58 and 1.59 (using the same intel compiler 16.0).
KitturGanesh
Thanks Charles, I'll file the issue with the developers and will keep you updated. Appreciate your patience till then.
Kittur
Charles_G_
Any updates? Were you able to reproduce the problem?
KitturGanesh
Hi Charles,
As mentioned I've already filed the issue (# DPD200409904) with the developers and is under investigation from their end. I'll keep you updated and will update you accordingly as and when I get an update from them.  Appreciate your patience till then. BTW, I've also let them know that you did inquire on the status as well, thanks.
Kittur
KitturGanesh
Hi Charles,
Just letting you know that this issue will be fixed in next update 4 release and I'll keep you updated as soon as the release with the fix is out. Appreciate your patience through this, as always.
Kittur
Jay_E_
Is there an approximate timeframe for update 4? I'm having the same problem.
TimP
Wasn't it mentioned on the forum that 2016 update 4 should appear next month?
Kevin_D_Intel
I don't know if it was but its more like in the September time-frame, and that comes with all the standard caveats, disclaimers, not a promise, etc. There's always a chance something may delay that.
JenniferJ
There is an issue in boost and it should be fixed in boost 1.62: https://svn.boost.org/trac/boost/ticket/12242
Please try again with boost 1.62 and latest ICC 16.0 update 3. Let us know if it works.
Jennifer
