Community
cancel
Showing results for
Search instead for
Did you mean:
Compilation errors on standard header files in libc++
MacOS 10.10.3, Xcode 6.3.2, Intel Composer 2015 sp 3. Compiling against 10.10 (or 10.9) SDK, including any standard header (such as <algorithm>) that eventually includes cpp_type_traits.h or allocator.h, I get the errors below if the C++ standard library is set to libc++. The errors go away if I use libstdc++:
cpp_type_traits (from OS X 10.10/usr/include/c++/4.2.1/bits/cpp_type_traits.h)
line 379:  // For the immediate use, the following is a good approximation.
template<typename _Tp>
struct __is_pod     <— Error: expected an identifier
enum
__value = (sizeof(__detail::__test_type<_Tp>(0))
!= sizeof(__detail::__one))
// A stripped-down version of std::tr1::is_empty
struct __is_empty   <— Error: expected an identifier
private:
template<typename>
struct __first { };
template<typename _Up>
struct __second
: public _Up { };
public:
enum
__value = sizeof(__first<_Tp>) == sizeof(__second<_Tp>)
allocator.h
  // To implement Option 3 of DR 431.
template<typename _Alloc, bool = std::__is_empty<_Alloc>::__value>  <— Error : expected an identifier; the global scope has no “__value”; expected a “,” or “>”
struct __alloc_swap
{ static void _S_do_it(_Alloc&, _Alloc&) { } };
template<typename _Alloc>
struct __alloc_swap<_Alloc, false>  <— Error: a template argument list is not allowed in a declaration of a primary template
static void
_S_do_it(_Alloc& __one, _Alloc& __two)
// Precondition: swappable allocators.
if (__one != __two)
swap(__one, __two);
One of our engineers tracked this down to an xcconfig file that contained:
ICC_OTHER_CFLAGS = $(OTHER_CFLAGS) -wd177,1478,1899 -vec_report0 -use-msasm -no-cxxlib -isystem$(SDKROOT)/usr/include/c++/4.2.1
The orange option is deprecated but harmless; the red item apparently caused this problem. We can now build this module against libc++.
