I have a software compiled with VS 2010 64 bits + QT 5 + Boost. When I switch to Intel compiler I got :
a) A lot of errors when I compile the QT project :
https://bugreports.qt-project.org/browse/QTBUG-31701#comment-206787
b) When I try to compile some projects related to boost I got the following error :
Error 106 error LNK1104: cannot open file 'libboost_thread-iw-mt-gd-1_49.lib'
BTW: I only have an evaluation version, so before buying I must be sure that it compile and I have a performance boost.
Q_CORE_EXPORT is a macro that gets expanded to different values depending on the context in which it's compiled.
It isn't an identifier. It's a platform-dependent macro, and it's used to signal a class that's intended to be used across library boundaries. In particular, it's defined by the Qt core library and used by other Qt libraries.
I've managed to reproduce the error and I've sent a fix to Qt: https://codereview.qt-project.org/59839
