I tried to compile my existing project with Intel C++ compiler 15 under Xcode 5.1. I installed the Xcode plugin and rebuilt my project, but I got the following error message and the compilation was failed.
In file included from <built-in>:181: <command line>:1:10: fatal error: '-c' file not found #include "-c" ^ 1 error generated. problem occurred when compiling '/Users/xxx/NSColor+RBLCGColorAdditions.m' with the clang compiler (code 1)
I checked the compilation command line:
CompileICL Build/Intermediates/xxx.build/Release/xxx.build/Objects-normal/x86_64/NSColor+RBLCGColorAdditions.o xxx/NSColor+RBLCGColorAdditions.m cd "/Users/xxx" /usr/bin/icc-15.0 -x objective-c -arch x86_64 -dev-usr-root=/Applications/Xcode.app/Contents/Developer/usr -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk -mmacosx-version-min=10.7 -w1 -fpascal-strings -iquote /Users/xxx/Build/Intermediates/xxx.build/Release/xxx.build/xxx-generated-files.hmap -I/Users/xxx/Build/Intermediates/xxx.build/Release/xxx.build/xxx-own-target-headers.hmap -I/Users/xxx/Build/Intermediates/xxx.build/Release/xxx.build/xxx-all-target-headers.hmap -iquote /Users/xxx/Build/Intermediates/xxx.build/Release/xxx.build/xxx-project-headers.hmap -F/Users/xxx/Build/Products/Release -I/Users/xxx/Build/Products/Release/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I/Users/xx/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I/opt/tbb/include -I/Users/jh/box/folly -I/usr/local/include -include "" -c /Users/xxx/xxx/NSColor+RBLCGColorAdditions.m -o /Users/xxx/Build/Intermediates/xxx.build/Release/xxx.build/Objects-normal/x86_64/NSColor+RBLCGColorAdditions.o -MMD -MT dependencies -MF /Users/xxx/Build/Intermediates/xxx.build/Release/xxx.build/Objects-normal/x86_64/NSColor+RBLCGColorAdditions.d
As you could see, the switch `-include ""` was interpreted as `-include` and the next switch `-c` was interpreted as its argument.
I modified the xcspec file inside the plugin, commented out the following scripts:
1055 // Precompiled Headers 1056 // 1057 // -- location sensitive (argument hashing) -- 1058 // 1059 //{ Name = ICL_PREFIX_HEADER; 1060 // Category = PrecompiledHeaders; 1061 // Type = path; 1062 // DefaultValue = "$(GCC_PREFIX_HEADER)"; 1063 // CommandLineArgs = { "" = (); "<<otherwise>>" = (-include, "$(_icl_prefix_header_$(ICL_PRECOMPILE_PREFIX_HEADER))"); }; 1064 // AdditionalBuildSettings = { 1065 // _icl_prefix_header_YES = "$(PrecompFilesDir)/$(ICL_PREFIX_HEADER:base)$(ICL_PREFIX_HEADER:suffix)"; 1066 // _icl_prefix_header_NO = "$(ICL_PREFIX_HEADER)"; 1067 // }; 1068 // },
Then clang accepted the command line, but the compilation failed again when compiling a .mm file:
clang: warning: argument unused during compilation: '-MMD' In file included from /Users/xxx/XXDocument.mm:1: In file included from /Users/xxx/XXDocument.h:2: /Users/xxx/config.h:33:10: fatal error: 'array' file not found #include <array> ^ 1 error generated. problem occurred when compiling '/Users/xxx/XXDocument.mm' with the clang compiler (code 1) Command /usr/bin/icc-15.0 failed with exit code 1
I added "-std=gnu++11" in "Intel C++ Compiler 15.0 Command Line" -> "Additional C++ options", but it was not included in the actual command line. I have to replace it with <tr1/array>, but for other .cpp file which required to be C++11 code, this was invalid.
I also encountered thousands of codes complaining ARC:
/Users/xxx/XXDocument.h:50:42: note: property declared here @property (weak) IBOutlet NSOutlineView *myOutlineView; ^ /Users/xxx/XXDocument.mm:67:1: error: @synthesize of 'weak' property is only allowed in ARC or GC mode @implementation XXDocument ^ /Users/xxx/XXDocument.h:51:42: note: property declared here @property (weak) IBOutlet NSPopUpButton *arcPopUpButton; ^ /Users/xxx/XXDocument.mm:67:1: error: @synthesize of 'weak' property is only allowed in ARC or GC mode @implementation XXDocument ^ /Users/xxx/XXDocument.h:53:42: note: property declared here @property (weak) IBOutlet NSSearchField *findSearchField;
Anyway, this was an unpleasant attempt of Xcode + Intel compiler. Please let me know how to compile a serious project, not a "Hello, world!" one in the labs.
Hello Leo,
Thanks for your report.
I was able to reproduce the issue with -include "". It will be fixed in the upcoming updates of 15.0 compiler. Meanwhile there is an easier workaround for this - explicitly set 'Precompile Prefix Header' build setting to 'No'.
As for the other issues, the Xcode integration does not fully support compilation of Objective-C source files. In Xcode projects we recommend using Intel compiler to compile C/C++ code while letting Clang compiler to process Objective-C (via creating Build Rules for C/C++). Anyways you would not see a benefit from compiling Obj-C with ICC or ICL since they transparently compiled by clang at this moment.
For further improvement of our Xcode integration I would appreciate a reproducer project.
Denis
