% g++-8.2 --version
g++-8.2 (GCC) 8.2.0
Copyright (C) 2018 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
% icpc --version
icpc (ICC) 19.0.1.144 20181018
Copyright (C) 1985-2018 Intel Corporation. All rights reserved.
% cat test.cpp
#include <memory>
int main(int argc, char** argv)
return 0;
% icpc -gcc-name=gcc-8.2 -gxx-name=g++-8.2 -fno-exceptions -std=c++17 -o test test.cpp
In file included from /usr/local/gcc-8.2/include/c++/8.2.0/bits/shared_ptr_base.h(54),
from /usr/local/gcc-8.2/include/c++/8.2.0/bits/shared_ptr.h(52),
from /usr/local/gcc-8.2/include/c++/8.2.0/memory(81),
from test.cpp(1):
/usr/local/gcc-8.2/include/c++/8.2.0/bits/refwrap.h(102): error: class template "std::_Mem_fn_traits" has already been defined
_GLIBCXX_MEM_FN_TRAITS(noexcept, true_type, true_type)
from test.cpp(1):
/usr/local/gcc-8.2/include/c++/8.2.0/bits/refwrap.h(103): error: class template "std::_Mem_fn_traits" has already been defined
_GLIBCXX_MEM_FN_TRAITS(& noexcept, true_type, false_type)
from test.cpp(1):
/usr/local/gcc-8.2/include/c++/8.2.0/bits/refwrap.h(104): error: class template "std::_Mem_fn_traits" has already been defined
_GLIBCXX_MEM_FN_TRAITS(&& noexcept, false_type, true_type)
compilation aborted for test.cpp (code 2)
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
This is a known issue. We have an internal case CMPLRIL0-25481 to track it.
Viet Hoang (Intel) wrote:This is a known issue. We have an internal case CMPLRIL0-25481 to track it.
Thanks for the reply. Is there a workaround for now or do we have to wait for the next point release?
I dont see a workaround suggested in the case. So, I guess you have to wait for the fix.
Any ETA for this fix? this bug is currently blocking our upgrade from ICC 18 to 19, which in turn is blocking us from using all the C++17 features that all other compilers support.
Still not fixed with Intel C++ 19.0 Update 2.
Still not fixed with Intel C++ 19.0 Update 3.
this also seems like a blocker, eagerly awaiting fix :)
Still not fixed with Intel C++ 19.0 Update 4.
It's been nearly half a year since I originally reported this bug and we're still blocked from switching to v19. Is this ever going to get fixed or should we just give up waiting for it?
It should be fixed in 19.0 Update 5.
