The following code can not be compiled with the Intel C++ compiler and flag -Wshadow. The compilation gets stuck without any further error message. However, the code compiles fine with the Intel C++ compiler when neglecting the flag -Wshadow.
#include <boost/operators.hpp> class C : boost::ordered_euclidian_ring_operators1< C , boost::ordered_euclidian_ring_operators2< C, int , boost::ordered_euclidian_ring_operators2< C, double > > > { C (long i) {} }; int main() {}
I have tested and reproduced this issue with versions 13.1.3, 14.0.3, 16.0.4, 17.0.5, 18.0.4 and 19.0.4 of the Intel C++ compiler using boost versions 1.61.0 and 1.70.0.
In contrast, the same code compiles fine with flag -Wshadow with various versions of the GNU C++ compiler and the LLVM Clang C++ compiler.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Can you create a preprocessed file for us?
Thank you for the quick response.
Please find attached the preprocessed file generated with the Intel C++ compiler 19.0.4.243 and boost 1.70.0.
For the sake of completeness, I have also attached the preprocessed file obtained with the GNU C++ compiler 8.1.0 and boost 1.70.0.
Thank for the .i file. I'll look into it.
I've reported this issue to our compiler Engineer. Internal bug number is: CMPLRIL0-32173
