Intel® C++ Compiler
Compilation under Xcode failed
mikhail_k_4
I have a file that could be successfully compiled with Xcode native compiler. My attempt to switch project to the ICC fails, because of all files complied in the following way:
CompileICC /Users/misha/Library/Developer/Xcode/DerivedData/system-gikqgxovhcwspiekxsybjzxtxlrn/Build/Intermediates/dcs.build/Debug/libdcsQt.build/Objects-normal-asan/x86_64/controls.o gui/qt/controls.cpp
    cd /Users/misha/SharedW/svn/soac/trunk/common/pc/dcs
    /usr/local/bin/icc-16.0 -x c++ -arch x86_64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.11.sdk -mmacosx-version-min=10.11 -g -O0 -w1 -fno-omit-frame-pointer -D_LIBRARY_ -D_OS_MACOSX_ -DDEBUG=1 -D_GUI_QT_ -DQT_GUI_LIB -DQT_CORE_LIB -DQT_WIDGETS_LIB -DQT_SHARED -stdlib=libc++ -fvisibility=default -fpascal-strings -I/Users/misha/Library/Developer/Xcode/DerivedData/system-gikqgxovhcwspiekxsybjzxtxlrn/Build/Intermediates/dcs.build/Debug/libdcsQt.build/libdcs-txt.hmap -F/Users/misha/Library/Developer/Xcode/DerivedData/system-gikqgxovhcwspiekxsybjzxtxlrn/Build/Products/Debug -F/Developer/Qt5/clang_64/lib -F/Library/Frameworks -I/Users/misha/Library/Developer/Xcode/DerivedData/system-gikqgxovhcwspiekxsybjzxtxlrn/Build/Products/Debug/include -I/opt/boost/include -I/opt/BDB/include -I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.11.sdk/usr/include -Icore -I/Users/misha/SharedW/svn/soac/trunk/common/pc/dcs -I/Users/misha/SharedW/svn/soac/trunk/common/pc/dcs/.. -I/usr/local/include -I/System/Library/Frameworks/CarbonCore.framework/Headers -I/Developer/Qt5/clang_64/lib/QtCore.framework/Versions/5/Headers -I/Developer/Qt5/clang_64/lib/QtGui.framework/Versions/5/Headers -I/Developer/Qt5/clang_64/lib/QtWidgets.framework/Versions/5/Headers -I/Developer/Qt5/clang_64/mkspecs/macx-xcode -std=c++14 -pipe -pipe -fvisibility=hidden -c /Users/misha/SharedW/svn/soac/trunk/common/pc/dcs/gui/qt/controls.cpp -o /Users/misha/Library/Developer/Xcode/DerivedData/system-gikqgxovhcwspiekxsybjzxtxlrn/Build/Intermediates/dcs.build/Debug/libdcsQt.build/Objects-normal-asan/x86_64/controls.o -MMD -MT dependencies -MF /Users/misha/Library/Developer/Xcode/DerivedData/system-gikqgxovhcwspiekxsybjzxtxlrn/Build/Intermediates/dcs.build/Debug/libdcsQt.build/Objects-normal-asan/x86_64/controls.d
icc-16_0: command line warning #10121: overriding '-fvisibility=default' with '-fvisibility=hidden'
NOTE: Use of this header (bool_trait_def.hpp) is deprecated
NOTE: Use of this header (template_arity_spec.hpp) is deprecated
Command /usr/local/bin/icc-16.0 failed with exit code 2
The same command in console successfully compiles file, but under Xcode I always have "Command /usr/local/bin/icc-16.0 failed with exit code 2" What does it mean?
Erich_M_
Erich H. Machu
Sebastian-Brunner-Gasse 3, A 1130 Vienna, Austria,                                                April 29, 2016
erich.machu@hostprofis.at,             user name E1101E04D
Dear Sirs,
I have purchased the Intel XE 2016 Fortran developer software already some months ago but so far could not produce an executable code.
My problem: When in „Microsoft Developer Environment“ (MSDEV, also called “Fortran Power Station“), a certain Fortran code, consisting out of a main program called Starling_F90 + some 20 subroutines + common blocks, builds and executes without problems.
When in „Intel XE 2016 MS Visual Studio 2013”, exactly the same Fortran code, copied to directory .“..\Intel\Projects\Starling_F90“ does not build, due to an “error LNK2001: unresolved external symbol mainCRTStartup”, see log file below.
A „build error file“ is offered in „Microsoft Visual Studio“ but cannot be displayed. However there exists a „ file :///D:/INTEL/Projects/Starling_F90/Debug/BuildLog.htm “ which, when opened, reads as follows:
Build Log
 Build started: Project: Starling_F90, Configuration: Debug|Win32
Output
Linking...
Link /OUT:"Debug\Starling_F90.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE: "Debug\Starling_F90.exe.intermediate.manifest"
/MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"D:\INTEL\Projects\Starling_F90\Debug\Starling_F90.pdb" /SUBSYSTEM:CONSOLE
/IMPLIB:"D:\INTEL\Projects\Starling_F90\Debug\Starling_F90.lib" "Debug/DISCLAIMER.res"
Link: warning #10013: no objects specified for multi-file optimization
LINK : warning LNK4068: /MACHINE not specified; defaulting to X86
LINK : error LNK2001: unresolved external symbol mainCRTStartup
Debug\Starling_F90.exe : fatal error LNK1120: 1 unresolved externals
Starling_F90 - 2 error(s), 2 warning(s)
My questions:
  1. What has to be done to execute program Starling_F90 in INTEL XDK + MS Visual Studio?
  2. How can the error “unresolved external symbol mainCRTStartup “ be repaired?
  3. How can the error file be displayed in MS Visual Studio?
  4. Do you see any other problems?
Thanking in advance for your help and kind regards, Erich H. Machu
KitturGanesh
Hi Mikhail,
Pardon me the issue's transferred to the fortran forum for the second issue posted in your thread :-(  Well, the developers say they need a reproducer to investigate further as they can't do so with just the information you have in the description, appreciate much.
Kittur
Hi Folks,
I've transferred the second issue in this thread to the Fortran forum so support engineers for Fortran can address that and transfer back to C++ forum for the first issue if possible.
Kittur
KitturGanesh
Hi Erich,
Instead, can you please file a new issue in this Fortran forum? That way I'll transfer the original thread on Mac issue back to the C++ forum, appreciate much.
Kittur
KitturGanesh
Hi Mikhail,
Can you attach a preprocessed file (use -P option to generate the .i file) so I can investigate further? The exit code could be due to any number of factors and hence need a reproducer, appreciate much.
Kittur
Manfredo_d_
Was this issue solved? Or moved?
I am actually having a very similar error with ifort compilers in Xcode.
Viet_H_Intel
Can you create a thread with a test case in https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x?
