Intel® C++ Compiler
Compile error in the latest boost with c++11 option
lee__kyubeom
[Makefile]
GCC = /usr/local/bin/g++
CC = /opt/intel/bin/icpc
INC = -I/usr/boost_1_68_0
COMPILE_OPTION      =  -std=c++1y
all:; $(CC) $(INC) $(COMPILE_OPTION) main.cpp
[main.cpp]
#include <iostream>
#include <boost/unordered_map.hpp>
using namespace std;
int main()
 cout<<"hello!"<<endl;
 return 0;
I'm using intel c++ compiler 16.0.1 which is in parallel studio 2016 update 1 package.
If the option -std=c++11 exists, the compile is failed with error as follows:
boost/unordered/unordered_map.hpp(2201): error: exception specification is incompatible with that of previous function "boost::unordered::unordered_multimap<K, T, H, P, A>::swap" (declared at line 1317)
        BOOST_NOEXCEPT_IF(value_allocator_traits::is_always_equal::value&&boost::is_nothrow_swappable<H>::value&&boost::is_nothrow_swappable<P>::value)
If the option -std=c++11 is omitted, the compile succeeds. I think it might be a compile bug because g++(4.8.2) doesn't fail the compile.
The first of all, the license is expired. So, I cannot compile the test code with newer version of intel compiler.
Can I know whether this circumstance is bug or not?
Viet_H_Intel
You can get a free trial with newer compiler to verify the issue.
https://software.intel.com/en-us/parallel-studio-xe/choose-download/free-trial-cluster-linux-fortran ;
lee__kyubeom
This problem has been solved since 2016 update 3. Thank you.
