I got the compile error of "use of '/fp:
Compiler version is v11.0.074_ia32, using in MS VS2003. Compile option is following:
/c /I "..\..\src\am_peri"/D "_CONSOLE" /EHsc /MT /fp:fast /GR /YX"StdAfx.h" /Fp".\Release/libam_peri34.pch" /Fo".\Release/" /W3 /nologo /Qfp-speculationsafe /EHs /O3 /Op /QxW /Qparallel /Qglobal-hoist /Qprefetch /Zc:forScope
I have tried /Qfp-speculation:safe /fp:fast in VS2008 and it worked for me. Though I have not tried in VS2003. VS2003 is supported by Intel C++ compiler 11.0 so it should work.
Thank you for replying. But it still doesn't work.
I change the project property in VS2003 to set the /Qfp-speculation to safe, but result in command line is not "/Qfp-speculation:safe", it was "/Qfp-speculationsafe". Then, compile it,same compileerror wasappeared.
I created the "hello world" project. I have reproduced the issue. It seems there is bug in Integration of the compiler in VS IDE.
You may set this option from command line property page as work arround.
I will submit an issue report to Intel's compiler development team.
Om
/c /I "....srcam_peri"/D "_CONSOLE" /EHsc /MT /fp:fast /GR /YX"StdAfx.h" /Fp".Release/libam_peri34.pch" /Fo".Release/" /W3 /nologo /Qfp-speculationsafe /EHs /O3 /Op /QxW /Qparallel /Qglobal-hoist /Qprefetch /Zc:forScope
After deleting deprecated option "/Op", it is work.
Thanks toOm Sachan forreplying.
