I am working with Intel Compiler 9.1.038 and using a workflow that builds files in 2 steps:
1. Use the /P option in order topre-process the source file into a file.
2.Compiling the preprocessed file (result of #1).
I am compiling files that use boost::fusionand the workflow above is failing with the following compilation error:
error: space required between adjacent ">" delimiters of nested template argument lists (">>" is the right shift operator)
typedef map<:PAIR>< K0 , typename detail::as_fusion_element
Which basically means the compiler does not like nested template ends without separating spaces.
The weird thing, though, is that if instead of the workflow described above I simply compile the same exact file regularly - it succeeds.
Moreover, there were some warning messages I am getting with the 2 stage compilation that i'm not getting when I compile the file regularly.
I have narrowed down the issue to the following steps:
1. Create an Intel Compiler project through Visual Studio 2005.
2. Add Boost (in my case 1.34.1) to the additional include folders.
3. Add a new cpp file with the following code:
#include
void
myFunc(){
Compile it regularly - and it passes.
Compile it with /P and then compile the preprocessed file and it fails.
Any idea as to what is causing this behavior and how to resolve it?
Moshe.
This isa known. A fix is being implemented right now.
It's because of "<<"& ">>" in th code.
