I'm trying to compile the Spec CPU 2006 benchmarks with the Intel compiler, which I'm using for the first time. Apparently it uses headers from MS Visual Studio, but in some cases it can't compile them. The following errors are failing to compile the MS header "yvals.h". Does anyone know why this might not work? Are there other flags I need to pass?
icl -Qvc9 -c -FoCompute.obj -DSPEC_CPU -DNDEBUG -DSPEC_CPU_WINDOWS -DWIN32ERFC -QxHOST -Qipo -O3 -Qprec-div- -Qparallel -Qansi-alias -Qopt-prefetch -Qcxx-features -Qauto-ilp32 /TP Compute.C Compute.C C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\INCLUDE\yvals.h(666): error: expected a ";" __CLR_OR_THIS_CALL _Lockit(const _Lockit&) = delete; ^ C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\INCLUDE\yvals.h(667): error: expected a ";" _Lockit& __CLR_OR_THIS_CALL operator=(const _Lockit&) = delete; ^ C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\INCLUDE\stddef.h(36): error: identifier "__nullptr" is undefined namespace std { typedef decltype(__nullptr) nullptr_t; } ^ C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\INCLUDE\stddef.h(36): error: expected a ";" namespace std { typedef decltype(__nullptr) nullptr_t; } ^ C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\INCLUDE\stddef.h(37): error: namespace "std" has no member "nullptr_t" using ::std::nullptr_t;
should not use /Qvc9. It means to set the icl to be compatible with VS2008. But you're using VS2012.
Just remove /Qvc9, icl will set the correct mode from the cl on the path or VS IDE.
Jennifer
Thanks, that works! Now there is a strange problem in just one benchmark:
icl -c -Foblock_sparse_matrix.obj -DSPEC_CPU -DNDEBUG -DSPEC_CPU_WINDOWS -Iinclude -DBOOST_DISABLE_THREADS -Ddeal_II_dimension=3 -QxHOST -Qipo -O3 -Qprec-div- -Qparallel -Qansi-alias -Qopt-prefetch -Qcxx-features -Qauto-ilp32 -DDEAL_II_MEMBER_VAR_SPECIALIZATION_BUG block_sparse_matrix.cc block_sparse_matrix.cc include\lac/block_indices.h(217): error: no instance of function template "std::make_pair" matches the argument list argument types are: (int, unsigned int) return std::make_pair<unsigned int>(block, i-start_indices[block]);
Here is the code that is failing, which clearly has a syntax error:
inline std::pair<unsigned int,unsigned int> BlockIndices::global_to_local (const unsigned int i) const { Assert (i<total_size(), ExcIndexRange(i, 0, total_size())); int block = n_blocks-1; while (i < start_indices[block]) --block; return std::make_pair<unsigned int>(block, i-start_indices[block]); }
Since this is shipping with the official Spec CPU 2006, I would assume the intention is for "int block" to be converted into "unsigned int" when added to the pair. Is there a compiler setting to make this possible? I would normally just tweak the code, but Spec has this crazy MD5 verification that will block everything if I touch the source files.
Yes, it's a bug in the spec source.
There are patches for the fix already on the spec site http://www.spec.org/cpu2006/src.alt/. Please look for patches from:
- 13 February 2014
- or 30 July 2013
Jennifer
Thanks! I have all the benchmarks working now.
